Changing to unlimited
- Re: Changing to unlimited
07-06-2009 10:27 AM
Does it have any drawbacks at which point in the month I change ( like just before or just after payment is made for the month ) my product from BBYW option 2 to 'unlimited' or does it not matter ?
Hope that makes sense
Thanks.
07-06-2009 10:30 AM
Even if I am wrong and it happens immediately they would just take a part payment for the difference
Either way so it doesn't matter unless you want to get onto unlimited quickly, in which case I would do it before your DD payment is requested otherwise you might be stuck on BBYW for another month
07-06-2009 10:32 AM
07-06-2009 10:33 AM
07-06-2009 11:18 AM
thanks.
07-06-2009 11:22 AM
I should watch your ticket and, if it says 18 months, ask for confirmation you are on a 12 month contract then it is in writing.
If your existing hardware works fine then there is no need to change it.
07-06-2009 12:38 PM
thanks for help.
Fenster.
07-06-2009 1:46 PM
jim:blue excessive smileys removed as per forum rules mod:end
07-06-2009 1:51 PM
Quote from: Fenster I don't need hardware really as everything works fine, just didn't see it offered at any stage in my product change, or a mention of 12 months instead of 18, I could be mistaken of course.
Check out Mand's posting on this thread:
http://community.plus.net/forum/index.php/topic,74429.0.html
07-06-2009 2:00 PM
07-06-2009 8:52 PM
Quote from: Oldjim I think the change will normally happen at your next billing date
Account changes are scheduled for your next billing date.
@Fenster, your account change is scheduled for 10th June.
08-06-2009 11:27 AM
