Change to ADSL2+
- Re: Change to ADSL2+
Change to ADSL2+
31-01-2011 8:13 PM
Is it worth me moving to ADSL2+ My line speed was estimated to be 3.5Mbps so I didn't think it worth me moving to ADSL2+ but I seem to be fairly regularly getting a little over 4000kpbs. Is it worth me moving, my router is currently showing the following information which all seems relevant:
Statistics Downstream Upstream
Line Rate 5760 Kbps 448 Kbps
Noise Margin 6.5 dB 23.0 dB
Line Attenuation 39.5 dB 28.5 dB
Output Power 19.8 dBm 12.3 dBm
I know my current modem is not compatible with ADSL2+ but that's easily sorted. I think I'm still in my initial 10 days of the service bedding down. I was with madasafish.com but I had some connection problems when I moved my modem so they had to reset the line.
Using some of the online tests (Kitz is it?) the speed seems to be around 9000Kbps, but I presume this is the maximum possible? Any advice gratefully received
Chisy
Chisy
Message 1 of 2
(522 Views)
1 REPLY 1
01-02-2011 11:24 AM
HI Chisy,
I reckon with those stats you could well see an improvement on ADSL2+
Jojo
Jojo
Message 2 of 2
(273 Views)
