Adsl2/Llu
- Adsl2/Llu
Adsl2/Llu
31-01-2011 1:13 PM
Re: Adsl2/Llu
31-01-2011 3:07 PM
Put your attenuation into Kitz's calculator here to get a view of likely speeds.
Re: Adsl2/Llu
31-01-2011 3:25 PM
Quote from: john50 would a Llu like Be give faster speeds.
Well Be specifically MIGHT if you have variations/intereference on your line (or wiring), because:
1. There's no BT-style DLM to keep speeds at a "lowest common denominator"
2. On some (but not all) of their packages there's a degree of "tweaking" allowed
That said, on longer lines ADSL2+ is not significantly better than ADSL1 and "tweaking" can actually be counterproductive.
Though on Be the default upstream speed will be pretty close to 1.3mbps except in the most extreme situations as it's always uncapped.
Post your downstream attenuation and router stats here for comment.
Re: Adsl2/Llu
31-01-2011 3:59 PM
Link Information
Uptime: 0 days, 4:01:16
DSL Type: G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 2,304
Output Power (Up/Down) [dBm]: 12.0 / 17.0
Line Attenuation (Up/Down) [dB]: 31.0 / 58.0
SN Margin (Up/Down) [dB]: 10.0 / 7.5
Vendor ID (Local/Remote): TMMB / TSTC
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 70 / 0
FEC Errors (Up/Down): 0 / 19,925
CRC Errors (Up/Down): 0 / 79
HEC Errors (Up/Down): 0 / 76
Kitz' comes up with 3200 on adsl2 and llu
Re: Adsl2/Llu
31-01-2011 4:30 PM
We tend to say not to bother if the expected rate is less than 4000k. However, there are occasions where users have seen the benefit with a line as long as yours.
Jojo
Re: Adsl2/Llu
31-01-2011 5:00 PM
So when adsl2 becomes available it might be worth trying, would I be able to roll back if it caused any issues?
Re: Adsl2/Llu
31-01-2011 5:12 PM
My advise would be not to move, but it's your call at the end of the day. Rolling back could involve a significant amount of downtime and not always possible.
Jojo
Re: Adsl2/Llu
31-01-2011 5:39 PM
Re: Adsl2/Llu
31-01-2011 6:04 PM
Re: Adsl2/Llu
31-01-2011 11:59 PM
I suppose I mean't both of us to move
Re: Adsl2/Llu
01-02-2011 10:28 AM
Re: Adsl2/Llu
01-02-2011 11:08 AM
