Can't get into my seedbox
- Re: Can't get into my seedbox
27-02-2014 11:58 PM
28-02-2014 12:02 AM
Record the gateway you're currently on so that networking can investigate any issues if that works.
28-02-2014 12:05 AM
28-02-2014 12:17 AM
Edit: I did actually disconnect/reboot my router today, I don't know if restart changed the gateway as I didn't check.
28-02-2014 9:50 AM
Before disconnecting my router I was on PTN-AG04 and I couldn't login into my seedbox however after disconnect/reconnect I was on PCL-AG04 and I manage to login into my seedbox without issue however it only lasted 10 mins and I got disconnect since that I had 30 min success on PCL-AG04 before that stopped working again. There is definately some thing is not right on plus net side.
It has been working fine for months before this issue.
28-02-2014 9:54 AM
C:\Users\Home>tracert freak.seedhost.eu
Tracing route to freak.seedhost.eu [5.79.67.33]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms 192.168.0.1
2 * * * Request timed out.
3 30 ms 37 ms 28 ms lo0-central10.pcl-ag08.plus.net [195.166.128.189
4 23 ms 23 ms 26 ms link-b-central10.pcl-gw02.plus.net [212.159.2.19
0]
5 22 ms 22 ms 23 ms xe-9-1-0.pcl-cr02.plus.net [212.159.0.222]
6 25 ms 26 ms 26 ms ae2.pcl-cr01.plus.net [195.166.129.6]
7 23 ms 22 ms 23 ms ae1.ptw-cr01.plus.net [195.166.129.0]
8 23 ms 23 ms 23 ms peering.thn.lon.leaseweb.net [195.66.225.56]
9 32 ms 32 ms 31 ms 31.31.32.73
10 * * * Request timed out.
11 * * * Request timed out.
12 * * * Request timed out.
13 * * * Request timed out.
14 * * * Request timed out.
15 * * * Request timed out.
16 * * * Request timed out.
17 * * * Request timed out.
18 * * * Request timed out.
19 * * * Request timed out.
20 * * * Request timed out.
21 * * * Request timed out.
22 * * * Request timed out.
23 * * * Request timed out.
24 * * * Request timed out.
25 * * * Request timed out.
26 * * * Request timed out.
27 * * * Request timed out.
28 * * * Request timed out.
29 * * * Request timed out.
30 * * * Request timed out.
Trace complete.
C:\Users\Home>
28-02-2014 10:41 AM
Pinging seedhost.eu [85.214.229.249] with 32 bytes of data:
Reply from 85.214.229.249: bytes=32 time=48ms TTL=50
Reply from 85.214.229.249: bytes=32 time=47ms TTL=50
Ping statistics for 85.214.229.249:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 47ms, Maximum = 48ms, Average = 47ms
C:\Users\Home>ping freak.seedhost.eu
Pinging freak.seedhost.eu [5.79.67.33] with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 5.79.67.33:
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
C:\Users\Home>
28-02-2014 10:45 AM
Ex-Broadband Service Manager
28-02-2014 10:54 AM
28-02-2014 11:40 AM
Can I Just ask are you trying to access the seed box via SSH or FTP? I ask because I have had a problem for over a week now being unable to get into mine via SSH. but can get in via FTP on port 21.. Im about to try another method later today called Swish. I will let you know if it works ok or not,
Regs Osh
28-02-2014 4:58 PM
Quote from: Inam As I said earlier I can't access my seedbox on my IPAD as well when using plus net connection however if I change that to 3g connection then there are no issues. Also changing gateway got me into my seedbox for 30 mins before connection stopped working again.
Is it possible you're tripping some kind of security system at the providers end, e,g tryign to make to many FTP connections, accidentally logging in with with the wrong password.
I've seen people get blocked from various servers before by having the wrong password stored in their FTP client and combined with the automatic retry on a lot of clients it can have already tripped the security system before the user notices the password was wrong.
28-02-2014 5:48 PM
@dragon2611, Password is correct as I manage to get into my seedbox for 30 mins also checked with seedhost support and every seem to working fine on their end.
Seedhost customer support thinks there is a routing issue with plus net. It works fine on my mobile or Ipad over 3g connection but it doesn't work if I use plus net connection.
28-02-2014 7:13 PM
Quote Last login: Fri Feb 28 19:06:41 on ttys000
mbpa:~ andrewroberts$ traceroute freak.seedhost.eu
traceroute to freak.seedhost.eu (5.79.67.33), 64 hops max, 52 byte packets
1 192.168.0.1 (192.168.0.1) 1.770 ms 1.142 ms 1.995 ms
2 lo0-central10.pcl-ag04.plus.net (195.166.128.185) 20.722 ms 20.294 ms 20.261 ms
3 link-a-central10.pcl-gw01.plus.net (212.159.2.172) 20.831 ms 23.041 ms 20.659 ms
4 xe-0-2-0.pcl-cr01.plus.net (212.159.0.204) 19.592 ms 19.623 ms 19.238 ms
5 ae1.ptw-cr01.plus.net (195.166.129.0) 19.988 ms 19.740 ms 19.900 ms
6 peering.thn.lon.leaseweb.net (195.66.225.56) 21.008 ms 20.725 ms 21.813 ms
7 31.31.32.65 (31.31.32.65) 27.218 ms
31.31.32.75 (31.31.32.75) 30.682 ms
31.31.32.71 (31.31.32.71) 32.479 ms
8 85.17.100.115 (85.17.100.115) 29.244 ms 29.989 ms 27.707 ms
9 5.79.79.241 (5.79.79.241) 32.401 ms
5.79.79.239 (5.79.79.239) 28.552 ms 31.859 ms
10 freak.seedhost.eu (5.79.67.33) 28.942 ms 28.028 ms 27.198 ms
Does sound like a firewall or some sort of security system issue.
28-02-2014 11:53 PM
01-03-2014 1:10 PM
