Can I have a speed reset please
Legend
Fixes: 255
Re: Can I have a speed reset please
@steve_arnold Keep your ears (and eyes) on this. Your test calls could have temporarily cleared the noise, but without a proper investigation, we will not know if the problem has really been fixed.
steve_arnold
Apologies for not posting a update sooner, I raised a ticket and the reply said they had changed some settings but nothing changed, for the last 10 days I hadn't checked as busy looking after my nan.
To my surprise just checked the router and with a uptime or 36hrs it's reporting this - unsure when I reset the stats.
  Status
xDSL
xDSL
Mode ADSL_2plus
Traffic Type ATM
Status Up
Link Power State L0
  Downstream Upstream
Line Coding (Trellis) On On
SNR Margin (dB) 15.8 5.7
Attenuation (dB) 42.0 26.5
Output Power (dBm) 0.0 12.6
Attainable Rate (Kbps) 7352 1168
Rate (Kbps) 6979 1167
MSGc (# of bytes in overhead channel message) 59 12
B (# of bytes in Mux Data Frame) 218 35
M (# of Mux Data Frames in FEC Data Frame) 1 1
T (Mux Data Frames over sync bytes) 1 4
R (# of check bytes in FEC Data Frame) 0 0
S (ratio of FEC over PMD Data Frame length) 0.9994 0.9795
L (# of bits in PMD Data Frame) 1753 294
D (interleaver depth) 1 1
Delay (msec) 0 0
INP (DMT symbol) 0.00 0.00
Super Frames 0 0
Super Frame Errors 1099 1786
RS Words 0 3109268
RS Correctable Errors 0 0
RS Uncorrectable Errors 0 0
HEC Errors 478 3403
OCD Errors 0 0
LCD Errors 0 0
Total Cells 2142194059 357876818
Data Cells 6739378 1319930
Bit Errors 11476 15317
Total ES 196 997
Total SES 22 7
Total UAS 231 209
Legend
Fixes: 255
That looks much better, @steve_arnold , apart from the D/S SNR, but as mine has been running for over 60 days with a similar value, you may be on the way to a resolution. I'd just keep my eyes on it, and don't reset the stats - that can lead us up the wrong path.
steve_arnold
Hi again,
Had a resync 2hours ago, I didn't reset the stats but they appear to have gone strange:
  Status
xDSL
xDSL
Mode ADSL_2plus
Traffic Type ATM
Status Up
Link Power State L0
  Downstream Upstream
SNR Margin (dB) 12.9 5.6
Attenuation (dB) 42.0 26.6
Attainable Rate (Kbps) 9108 1176
Rate (Kbps) 8663 1176
MSGc (# of bytes in overhead channel message) 51 12
B (# of bytes in Mux Data Frame) 154 36
T (Mux Data Frames over sync bytes) 2 4
S (ratio of FEC over PMD Data Frame length) 0.5706 1.0000
L (# of bits in PMD Data Frame) 2173 296
Delay (msec) 0 0
Super Frames 0 0
Super Frame Errors 6489 598
RS Words 0 1269005
HEC Errors 162617 1357
OCD Errors 8 0
LCD Errors 8 0
Total Cells 182000905 24645235
Data Cells 1254252 306386
Bit Errors 28429 5993
Total ES 485 279
Total SES 105 5
Total UAS 202 104
Legend
Fixes: 255
Steve, that looks better. Why do you think they've gone strange? - the ones I an make sense of seem to have improved.
steve_arnold
Looks strange to me as upstream HEC errors, bit errors, total ES, total SES and total UAS along with downstream total UAS have gone down - surely they accumulate until reset?
Steve
Legend
Fixes: 255
@steve_arnold Sorry, hadn't really looked at those as the main indicators had improved. To be honest, can't remember if you said which modem/router you were using, but the overload of data on there is a little OTT for a home user. Maybe the data is reset on a re-sync?
RealAleMadrid
Aspiring Hero
Fixes: 59
@steve_arnold  Upstream errors are reported by the DSLAM in the fibre cab so that has probably been reset or restarted recently so the error counts would restart from zero.
Legend
Fixes: 255
@RealAleMadrid He's on ADSL, 😁
RealAleMadrid
Aspiring Hero
Fixes: 59
OK same difference, the DSLAM in the exchange.😛
steve_arnold
Hi again,
Only 1 further disconnect a week ago due to a power loss affecting our block of houses, the noise on the line has gone but this morning answered a call from a friend who lives about a mile away and immediately the connection dropped, it's remained connected for all other calls. As they call at the same time every week if the disconnects keep happening at the same time would that mean it could be a fault on their line.
One other thing is my attainable rate is showing as less than my actual rate since the power cut.
  Status
xDSL
xDSL
Mode ADSL_2plus
Traffic Type ATM
Status Up
Link Power State L0
  Downstream Upstream
SNR Margin (dB) 11.1 5.4
Output Power (dBm) 0.0 12.3
Attainable Rate (Kbps) 8472 1148
Rate (Kbps) 8791 1151
B (# of bytes in Mux Data Frame) 156 35
S (ratio of FEC over PMD Data Frame length) 0.5696 0.9931
L (# of bits in PMD Data Frame) 2205 290
Delay (msec) 0 0
Super Frames 0 0
Super Frame Errors 27641 2654
RS Words 0 60368
HEC Errors 272191 6830
OCD Errors 2 0
LCD Errors 2 0
Total Cells 575225687 75219428
Data Cells 6385722 532110
Bit Errors 7842 8664
Total ES 4718 1346
Total SES 425 15
Total UAS 455 325
Steve
Legend
Fixes: 255
@steve_arnold Do you get many incoming/outgoing calls - seems strange that one caller alone can drop the connection. If the same thing happens again, run a Quiet Line Test as soon as possible and check for noise. It could be a fault on their line, but only they will know if it affects others they call. Can you try calling them, and see if the same thing happens?
Actual/attainable rates sometimes seem mismatched, I have seen it on my old router (but not the current one).
Couple of other points (1) Does your router report connection times - how long it has been connected for? (2) Your errors look a bit high, but without a time-frame, that's a little difficult to interpret.
steve_arnold
Last resync was at 0901 today when we answered the phone, previous resync was at around 1115 last Thursday when the power cut out. Managed to telnet into the router does any of this make sense to anyone?
 ADSL info --stats
adsl: ADSL driver and PHY status
Status: Showtime
Last Retrain Reason:    8000
Last initialization procedure status:   0
Max:    Upstream rate = 1148 Kbps, Downstream rate = 7856 Kbps
Bearer: 0, Upstream rate = 1151 Kbps, Downstream rate = 8791 Kbps
Link Power State:       L0
Mode:                   ADSL2+ Annex A
TPS-TC:                 ATM Mode(0x0)
Trellis:                U:ON /D:ON
Line Status:            No Defect
Training Status:        Showtime
                Down            Up
SNR (dB):        9.4             5.5
Attn(dB):        42.0            26.6
Pwr(dBm):        0.0             12.3
                        ADSL2 framing
                        Bearer 0
MSGc:           51              12
B:              156             35
M:              1               1
T:              2               4
R:              0               0
S:              0.5696          0.9931
L:              2205            290
😧           1               1
                        Counters
                        Bearer 0
SF:             2269929         184660
SFErr:          126             167
RS:             0               2387171
RSCorr:         0               0
RSUnCorr:       0               0
                        Bearer 0
HEC:            228             126
OCD:            2               0
LCD:            2               0
Total Cells:    764108292               99930082
Data Cells:     7436252         620109
Drop Cells:     0
Bit Errors:     9401            9619
ES:             4746            1361
SES:            425             15
UAS:            455             325
AS:             36856
                        Bearer 0
INP:            0.00            0.00
INPRein:        0.00            0.00
delay:          0               0
PER:            16.23           17.87
OR:             28.08           8.05
AgR:            8785.68 1155.48
Bitswap:        6631/6631               0/0
Total time = 10 days 2 hours 8 min 37 sec
FEC:            0               0
CRC:            27669           2678
ES:             4746            1361
SES:            425             15
UAS:            455             325
LOS:            32              0
LOF:            45              0
LOM:            19              0
Retr:           5
Latest 15 minutes time = 8 min 37 sec
FEC:            0               0
CRC:            0               0
ES:             0               0
SES:            0               0
UAS:            0               0
LOS:            0               0
LOF:            0               0
LOM:            0               0
Retr:           0
Previous 15 minutes time = 15 min 0 sec
FEC:            0               0
CRC:            3               2
ES:             3               2
SES:            0               0
UAS:            0               0
LOS:            0               0
LOF:            0               0
LOM:            0               0
Retr:           N/A
Latest 1 day time = 2 hours 8 min 37 sec
FEC:            0               0
CRC:            20              8
ES:             20              7
SES:            0               0
UAS:            0               0
LOS:            0               0
LOF:            0               0
LOM:            0               0
Retr:           0
Previous 1 day time = 24 hours 0 sec
FEC:            0               0
CRC:            3085            220
ES:             450             139
SES:            55              0
UAS:            61              51
LOS:            1               0
LOF:            9               0
LOM:            10              0
Retr:           1
Since Link time = 10 hours 14 min 15 sec
FEC:            0               0
CRC:            126             167
ES:             118             108
SES:            0               0
UAS:            0               0
LOS:            0               0
LOF:            0               0
LOM:            0               0
Retr:           0
NTR: mipsCntAtNtr=0 ncoCntAtNtr=0
Legend
Fixes: 255
Not a great deal - to me.😉
But the times reported on there don't seem to tally - it says you've been up for 10 days, but you reported that it re-synced this morning. 😕
steve_arnold
Summary page from router seems to show it didn't reboot with the power cut either although other electrical devices went off for around 10 seconds.
  Status
Device Information
Model Name BiPAC 8900AX R2
Host Name home.gateway
System Up-Time 19D 4H 30M 54S
Date/Time Thu Nov 19 20:29:00 2020
Software Version 2.50a.d16
LAN IPv4 Address 192.168.1.254
LAN IPv6 Address fe80::6203:47ff:fe39:91ca/64
MAC Address 60:03:47:39:91:ca
DSL PHY and Driver Version A2pv6F039r.d26e
Wireless Driver Version 7.14.43.21.cpe4.16L02A.0-kdb
WAN
Line Rate - Upstream (Kbps) 1151
Line Rate - Downstream (Kbps) 8791
Default Gateway / IPv4 Address pppoa0 (DSL) / (my static IP redacted)
Connection Time 11:28:08
Primary DNS Server 8.8.8.8
Secondary DNS Server 8.8.4.4
