CHAP authentication fail
- Re: CHAP authentication fail
02-12-2010 12:34 PM
Hi all, ive been waiting for my broadband connection to activate since placing me new order with you and i woke up this morning to my routers DSL light on which is great. However i cant get interent access as im getting CHAP authentication failed errors when trying to connect, ive googled this and that seems to be a username/password issue but im 100% sure mine is correct, if anyone could shed some light on this issue that would be great
My plusnet username is craftylee
Many thanks,
Lee
Many thanks,
Lee
Message 1 of 4
(1,792 Views)
3 REPLIES 3
02-12-2010 1:03 PM
You don't be able to connect until your account is set active in our system. I suspect that BT have finished the work and we just haven't got the order complete message back yet. I don't have the access to double check, but one of the digi care guys should be able to, and barring any other issues, activate your account Won't be long now!
Kelly Dorset
Ex-Broadband Service Manager
Message 2 of 4
(434 Views)
02-12-2010 1:15 PM
Hi Craftylee,
As Kelly said the order is still not showing as complete. I have, however, perfomed some maintenance on your account that may enable you to connect. If you have any difficulties then unfortunately you will have to wait until tomorrow until the order completes.
Jojo
Jojo
Message 3 of 4
(434 Views)
02-12-2010 1:16 PM
whatever you did it worked and im connected and using my connection now!
thanks very much!
thanks very much!
Message 4 of 4
(434 Views)
