Upstream rate now capped & BT profile fixed to 2500
- Upstream rate now capped & BT profile fixed to 250...
01-12-2010 4:15 AM
My Router Stats Uptime 118:06:09 Hours
ADSL Link Downstream Upstream
Connection Speed 6357 kbps 440 kbps
Line Attenuation 41.5 db 22.2 db
Noise Margin 6.0 db 25.5 db
Plusnet line speed
4 - Checked on 2010-10-04 14:09:11
Current line speed:
5500
BT Sppedtest
Download speedachieved during the test was - 2269 Kbps
For your connection, the acceptable range of speedsis 1200-4000 Kbps.
Additional Information:
Your DSL Connection Rate :6357 Kbps(DOWN-STREAM), 440 Kbps(UP-STREAM)
IP Profile for your line is - 2500 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 12.73:21.08:66.2 (SBE:NBE:PBE)
These figures represent the ratio while sententiously passing Sub BE, Normal BE and Priority BE marked traffic.
The results of this test will vary depending on the way your ISP has decided to use these traffic classes.
Upload Speed
320 Kbps
0 Kbps 440 Kbps
Max Achievable Speed
>Upload speed achieved during the test was - 320 Kbps
Upstream Rate IP profile on your line is - 440 Kbps
I have called the faults team several times and they don't seem unable or unwilling to do anything about the stuck BT profile. I did query the capped upload an I was told that everyone has a capped upload.
I don't mind taking part in trails to help improve broadband for others. but don't kick me into the long grass when thing get complicated.
Re: Upstream rate now capped & BT profile fixed to 2500
01-12-2010 11:55 AM
Everyone's upload is capped unless otherwise requested and as for the profile, the no DLM will just stop your line from being banded and allow it to sync at it's highest rate, but a profile will still be set depending on the sync rate. I'll check a few things out and let you know what I find.
Jojo
01-12-2010 12:09 PM
Quote from: ctech500 I have been on a trail........
I know it is considered bad form to criticise spelling but I found it hard to make sense of this post until I realised that ctech500 means trial when he/she writes "trail"
01-12-2010 12:27 PM
01-12-2010 12:31 PM
Having just ran a line test your PN & BT profiles are both 5500. Are you not seeing this now?
Jojo
01-12-2010 4:40 PM
Sorry about the Typo, It was late and I did it in a hurry
Ok I have done a BT and Mybroadband speed test and the results are shown below
I had my upload speed uncapped because I was on the BT21CN trial. when I opted for the NO DLM trial
Results Image not loaded
Test1 comprises of Best Effort Test: -provides background information.
Download Speed
2267 Kbps
0 Kbps 4000 Kbps
Download speed achieved during the test was - 2267 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 8.51:23.68:67.81 (SBE:NBE:PBE)
http://www.mybroadbandspeed.co.uk/results/64054011.png
02-12-2010 11:42 AM
When did you run that BT speed test? Because I've checked all BT systems available to me and they're all showing 5500 ip profile.
Jojo
02-12-2010 3:41 PM
I ran those tests yesterday afternoon, below is today's test
Download Speed
2756 Kbps
0 Kbps 4000 Kbps
Download speed achieved during the test was - 2756 Kbps
For your connection, the acceptable range of speeds is 1200-4000 Kbps.
The throughput of Best Efforts (BE) classes achieved during the test is - 27.55:18.13:54.32 (SBE:NBE:PBE)
I had a chat with one the guys on faults who informed me that it could be contention. But if this is the case why is BT speedtester showing me a profile of 2500 as highlighted
you can check my last two tickets to get a picture of what is going on
02-12-2010 3:54 PM
Hmm, something's amiss there because as you see your download speed is actually greater than your ip profile. I'll have a delve and see what I can come up with. Thanks for your help so far.
jojo
02-12-2010 4:35 PM
I'm posting my router Stats which will deepen the mystery further
Router Stats
Noise Margin: 6.0 dB Noise Margin: 25.1 dB
Connection Rate: 6357 Kbps Connection Rate: 440 Kbps
Line Attenuation: 41.5 dB Line Attenuation: 22.2 dB
Power: 0.0 dBm Power: 12.4 dBm
Max Rate 7396 Kbps Max Rate: 888 Kbps
Total Uptimes (From SF counts): WAN: 7 days, 17:46:25
02-12-2010 5:07 PM
Now that just makes my brain hurt. There's someone I need to seee about this but won't see him until tomorrow so hopefully we can get some answers then.
Jojo
