Broadband signal dropoffs
BoiWunda17
Broadband just cuts out semi regularly for around 5 minutes at a time. There is no pattern, it can be 5 times a day, or sometimes not at all for that day, just cuts out, flashes orange for 5ish minutes, and comes back on.
3 REPLIES 3
Fixes: 357
Re: Broadband signal dropoffs
@BoiWunda17 Welcome to the forums.
If the phone test passes, report a broadband problem via: https://www.plus.net/help/report-a-problem/broadband/
BoiWunda17
I don't have a house phone to do that with. I've been on the phone to Plusnet about this months ago. Typically, as I phoned them it stopped and never happened again until about two weeks ago.
Fixes: 357
OK, but a basic corded phone is a very useful tool while ever you are on an ADSL/FTTC connection.
It may be an idea to follow the below:
BT Broadband(obscuring your phone number) and BTW Performance Tester - Over a wired (Ethernet) connection if at all possible, please report the 'ADDITIONAL DIAGNOSTICS', and sight of the broadband connection status from your Hub (with the 'Username' obscured) would be a good starting point.
For the Hub One -
For the Hub Two -
