Broadband connection Issue
AHurley
Hi, The past few days I have had no broadband. The PlusNet router is flashing red / orange. Power light on Red.
I have tried resetting .
It is plugged directly into the master socket.
I have tried a different filter.
The phone (connected to the line) is working fine
Can anyone help please?
Thank you
2 REPLIES 2
Fixes: 385
Re: Broadband connection Issue
Sounds like you have an issue - I would call support.
tactilis
Text   HELP  to the Plusnet Fault Checker on 07800 008121 from the mobile that is registered with your account.
I will initiate a test and may fix it (it did for me), or will initiate next steps.
