Broadband activation
Fixes: 382
Re: Broadband activation
If you click the link, it should open a 'question' - if it does, scroll to the bottom , there should be a link that says 'I need to add further details' (or similar), click that and it should allow you to add your availability. NOTE: I'm working from memory on this as I'm no longer with Plusnet.
Mustrum
Fixes: 81
I am in a similar position, from memory - but seem to remember needed another tab logged into the member centre ?
Fixes: 382
@Mustrum You could be right, although when I last had to reply to a ticket, that was not needed, but the system has possibly been 'improved'.
gixxerdaz7
Thanks for that jab1 hopefully done it
appreciate that thanks again
Fixes: 1,662
Perfect, I can see we've booked the engineer and updated the ticket 221853028 with the appointment details.
Let us know how it goes Smiley
