reset password for username @plusdsl.net
markrdyson
Hi folks,
How do i reset my original sign up password, im sure there used to be a portal you could sign into to do it.
the one you use with your ................@plusdsl.net on the router to activate your line.
thanks
Mark
3 REPLIES 3
Fixes: 476
Re: reset password for username @plusdsl.net
@markrdyson  Welcome to the forum.
Go to the Member Centre log in page. Enter your username and select ‘Forgotten your Password’.  https://www.plus.net/member-centre/login
markrdyson
Thanks for the welcome.
I can get into the link you attached with user name and password,
Is that the same password i use when puting it into a new or old router to get access to the (adslLine) to get the internet working?
thanks
Mark
Fixes: 476
@markrdyson
Yes.
Your user name must be in the form [email protected]
