Broadband Speed Test - who do you believe?
- Re: Broadband Speed Test - who do you believe?
01-09-2010 2:37 PM
Hi,,
Just tested my broadband speed using PC World tester and Plusnet for comparison. I did two tests with each in quick succession and the results are as follows:-
PC World 2536kbps
Plusnet 5499kpbs
PC World 1949kpbs
Plusnet 5498kpbs
Upload speeds were similar at 350 - 390 kpbs with Plusnet showing higher speed.
I am not sure who is kidding who, so an explanation would be much appreciated, please.
Thanks,
Alex
PC World 2536kbps
Plusnet 5499kpbs
PC World 1949kpbs
Plusnet 5498kpbs
Thanks,
Alex
Message 1 of 7
(1,662 Views)
6 REPLIES 6
01-09-2010 2:47 PM
Why don't you see what results you get using this speed tester for further comparison.
Message 2 of 7
(661 Views)
01-09-2010 2:52 PM
Hi Alex, the most effective test has to be speedtester.bt.com or download the 50MB file from here on port 80
Jojo
Jojo
Message 3 of 7
(661 Views)
01-09-2010 5:39 PM
Quote from: Apprentice Why don't you see what results you get using this speed tester for further comparison.
Upload 6.3mbps
Download 0.7mbps
So, what does that tell you?
Message 4 of 7
(661 Views)
01-09-2010 6:29 PM
It would throw into doubt the results from the speed tester at PC World.
I tried the tester I found at PC World and it was unable to download a file due to a internal error.
Message 5 of 7
(661 Views)
01-09-2010 7:32 PM
I'd also try the new BBC iPlayer diagnostics: http://beta.bbc.co.uk/iplayer/diagnostics
All testers are unreliable and variable for reasons that are so wide-ranging there's no point even trying to list them.
Message 6 of 7
(661 Views)
06-11-2010 11:39 AM
Now thats interesting,Ive been doing some tests,just to see how good my connection really is (no complaints against PN just wanna see what Im getting). Anyhow,that PC World link,is to Australia for gawds sake !!!!!!!!!!!!!!!! Wont that make a hell of alot of difference,ie slower results,it is a long way you know
url=http://www.mybroadbandspeed.co.uk][img]http://www.mybroadbandspeed
[Moderator's note by Jim (Oldjim): Full quote of preceding post removed, as per Forum Rules ]
Message 7 of 7
(661 Views)
