Best time for a line re-set
- Re: Best time for a line re-set
24-03-2011 9:55 AM
If you're still having trouble getting the firmware upgraded let me know and I'll get it done from our end.
Jojo
24-03-2011 10:32 AM
24-03-2011 1:52 PM
You don't need to do anything but you will lose connectivity for about 10 minutes.
Jojo
24-03-2011 2:30 PM
24-03-2011 2:57 PM
It's done now.
Jojo
24-03-2011 6:34 PM
BTW does resetting to factory defaults effect the firmware? It maybe an idea to reset everything up from scratch. It usually takes a few reboots in between setting changes to make them work, don't want the exchange thinking it's discos a dropping my profile during a reset.
25-03-2011 4:44 PM
give me a nudge on Monday about the reset and I'll take a look. Factory resetting shouldn't change the firmware It'll just lose your details and wireless password etc.
Jojo
28-03-2011 1:33 PM
Cheers
28-03-2011 5:23 PM
I've reset that now for you. I'll check it later after my soaps
Jojo
29-03-2011 10:25 AM
Hopefully I should stay there, my router logs showed 3 loss of signals but that may be it reconnecting during the process I've reset my logs and will keep an eye out for anymore.
BTW you didn't switch my pc on did you ? I could have swore the computer was not knocked on yesterday and this morning my missus said it was on when she got up Can that even be done remotely?
29-03-2011 11:50 AM
Quote from: AverageWhiteBloke BTW you didn't switch my pc on did you ? I could have swore the computer was not knocked on yesterday and this morning my missus said it was on when she got up Can that even be done remotely?
I'm good... but not that good!
29-03-2011 12:42 PM
So is that done now or is it an ongoing process?
29-03-2011 1:53 PM
Your current sync rate is 5280k so your profile will lift again to 4500k if it stays like that.
Jojo
29-03-2011 9:30 PM
I just hope if I can keep the speed I can sort the router with my ps3.
30-03-2011 1:19 PM
Quote from: AverageWhiteBloke Out of curiosity what decides what speed it will stay at?
If you mean download speed then that is dependent on the IP profile. If you are talking about the sync speed then that is defined by your attenuation and SNR.
Jojo
