Bandwidth cut?
- Bandwidth cut?
Re: Bandwidth cut?
29-12-2010 3:19 PM
Thanks, Lloyd.
Re: Bandwidth cut?
29-12-2010 4:26 PM
There's no restriction on your sync rate now so it should sync at the highest possible. Are you in the master/test socket? That will make all the difference if not. As far as the banding goes there is a good chance it will be banded again if there's multiple disconnections.
Jojo
Re: Bandwidth cut?
29-12-2010 4:30 PM
Thanks, Lloyd.
Re: Bandwidth cut?
29-12-2010 4:34 PM
I'm not sure what system you were on before but banding only applies on ADSL2+
Jojo
Re: Bandwidth cut?
29-12-2010 4:45 PM
Lloyd.
Re: Bandwidth cut?
29-12-2010 4:49 PM
[quote=Joanne Pilson]Are you in the master/test socket? That will make all the difference if not.
just wonder about your set up there. Are you using the same router as before?
Jojo
Re: Bandwidth cut?
29-12-2010 4:59 PM
Quote from: 00lloyd Is was using ADSL2+ with BE. I used to restart/reboot whilst messing with modem/router settings all the time. My line never dropped below 18meg in 3 years.
Lloyd.
thought BE was LLU only?
Re: Bandwidth cut?
29-12-2010 5:05 PM
Lloyd.
BE, do but what difference does that make, is there no profiling on LLU?
Re: Bandwidth cut?
29-12-2010 5:25 PM
Well, that could make all the difference. I had a Netgear syncing at 17600 and when I changed it to the Thomson I now use I got 20004. I'd be interested to see what sync you would get with the Thomson.
Jojo
Re: Bandwidth cut?
29-12-2010 5:45 PM
Quote BE, do but what difference does that make, is there no profiling on LLU?
they dont use the stupid BT DLM on LLU
Re: Bandwidth cut?
29-12-2010 10:25 PM
Re: Bandwidth cut?
29-12-2010 10:37 PM
Re: Bandwidth cut?
29-12-2010 11:15 PM
Re: Bandwidth cut?
30-12-2010 12:45 AM
Re: Bandwidth cut?
30-12-2010 12:56 AM
