Bandwidth cut?
- Bandwidth cut?
Re: Bandwidth cut?
26-12-2010 7:52 PM
Thanks, Lloyd.
Re: Bandwidth cut?
26-12-2010 8:25 PM
Re: Bandwidth cut?
26-12-2010 9:22 PM
Re: Bandwidth cut?
27-12-2010 12:01 AM
Thanks, Lloyd.
Re: Bandwidth cut?
27-12-2010 9:25 AM
Sorry to hear you're having these issues early on, and from reading through the thread I would say you are probably banded with up to 1152 being your maximum sync rate. I would imagine that would be to do with what you said earlier...
[quote=00lloyd]I think its a wiring problem because my phone line was cutting out just before I got connected to PN about a week ago because of some wiring pulled out behind the master socket accidentally, and I just fiddled around with the phone line wiring (I do know what goes were but it still wasn't working) until it did work, so there's probably a weak hard-line connection somewhere.
At the moment though that's just speculation on my part until I investigate it further. But don't worry, thinking that's all you'll get from us in the way of speed. We'll make sure your connection performs at its best. The banding is there because it wouldn't hold a connection at a higher sync, so while there's a fault it enables the connectoin to become stable.
I'm going to take a look and see what I can find out.
when you say some wiring was pulled out behind the master socket, do you mean the wires that are attached to the back of the bottom part of the faceplate? Are you in the test socket right now?
Jojo
Re: Bandwidth cut?
27-12-2010 12:31 PM
As I have been saying, I've had a stable connection for years at about 18meg give or take with some sn margin fiddling.
So if I just hooked up another modem/router that supports sn margin altering could I just overide the banding by lowering it, or is that not how it works?
Thanks, Lloyd.
Re: Bandwidth cut?
27-12-2010 12:36 PM
If you're quite sure you have fixed the wiring issue I can have your SNR reset and the banding lifted. I need to contact BT for this but not sure of that departments opening hours on bank holiday. I will give them a try and let you know.
Jojo
Re: Bandwidth cut?
27-12-2010 12:44 PM
Uptime: 0 days, 23:23:59
DSL Type: G.992.5 annex A
Maximum Bandwidth (Up/Down) [kbps/kbps]: 888 / 18,128
Bandwidth (Up/Down) [kbps/kbps]: 440 / 1,150
Data Transferred (Sent/Received) [MB/MB]: 35.59 / 413.47
Output Power (Up/Down) [dBm]: 12.5 / 18.0
Line Attenuation (Up/Down) [dB]: 11.0 / 20.5
SN Margin (Up/Down) [dB]: 31.0 / 21.0
Loss of Link (Remote): 0
FEC Errors (Up/Down): 0 / 166
CRC Errors (Up/Down): 33 / 0
HEC Errors (Up/Down): 7 / 0
If you think it's all good then go for it.
Thanks, Lloyd.
Re: Bandwidth cut?
27-12-2010 12:53 PM
I'm afriad it seems there are no representative available today. I will have to do it Wednesday by the looks of things. The errors are nothing out of the ordinary. The stats are just reporting errors that have been corrected, which is normal.
Jojo
Re: Bandwidth cut?
27-12-2010 1:05 PM
Btw, where could find out about my contracts cooling off period, it seems no-one wants to tell me!
Thanks, Lloyd.
Re: Bandwidth cut?
27-12-2010 1:46 PM
I'm sorry to hear that you are considering cancelling, bearing in mind that it seems your current issue was not as a result of anything from plusnet's end. Although that said I'm confident I can remedy your problem. As far as a 'cooling off period' goes this will apply to broadband which has been ordered but not yet activated. Once we have incurred any costs in providing broadband then the contract will begin. Full details of our cancellation policy are available here.
Jojo
Re: Bandwidth cut?
27-12-2010 8:53 PM
Link Information
Uptime: 0 days, 7:58:44
Maximum Bandwidth (Up/Down) [kbps/kbps]: 888 / 17,920
Data Transferred (Sent/Received) [MB/MB]: 35.85 / 250.42
Line Attenuation (Up/Down) [dB]: 11.0 / 21.0
SN Margin (Up/Down) [dB]: 29.5 / 20.5
Loss of Signal (Local/Remote): 3 / 0
Error Seconds (Local/Remote): 3 / 0
FEC Errors (Up/Down): 0 / 238
CRC Errors (Up/Down): 0 / 0
HEC Errors (Up/Down): 0 / 0
It looks like it lost connection 8 hours ago... any ideas why? But surely with the sn margin this high it couldn't be because the line couldn't handle the speeds, they're already rock bottom! May this point to a hardwire error?
Re: Bandwidth cut?
27-12-2010 9:48 PM
It would be great if Plusnet could (optionally) email you when your profile changes and when you disconnect/connect, I know many wouldn't be interested in this data, but I would be.
Re: Bandwidth cut?
29-12-2010 2:30 PM
Thanks, Lloyd.
Re: Bandwidth cut?
29-12-2010 3:14 PM
I'm having this lifted now. I'll keep an eye on it because we'll have to wait for the profile to lift. This shouldn't take too long now.
Jojo
