Bad Upload Performance
Re: Bad Upload Performance
@bomster - you need to revisit the BTW speed tester and click the "Further Diagnostics" link, enter your phone number and then click "Run Diagnostic Test". That will send the results to the server, and you can copy and paste the outcome in to a reply - something like this:
1. Best Effort Test: -provides background information.
Download  Speed
14.02 Mbps
0 Mbps 21 Mbps
Max Achievable Speed
Download speedachieved during the test was - 14.02 Mbps
For your connection, the acceptable range of speeds is 4 Mbps-21 Mbps.
IP Profile for your line is - 15.19 Mbps
Upload Speed
0.85 Mbps
0 Mbps 0.83 Mbps
Upload speed achieved during the test was - 0.85Mbps
Additional Information:
Upstream Rate IP profile on your line is - 0.83 Mbps
Fixes: 10
Tip: You don't have to upload images to anywhere to post them on here. When you write your message click the Additional Options and Attachments where you will find the option to attach images to your post.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
bomster
Thanks for the tip. I'm using puush.me which takes a screen short and immediately uploads to the web and copies the link to your clipboard, you should check it out.
Anyway, I ran full diagnostics:
bomster
Anyone?
Fixes: 167
I'd suggest getting a fault ticket raised at https://faults.plus.net
There's something wrong and we'll need to look deeper into it with the results we get from the fault.
 Chris Parr
 Plusnet Staff
bomster
Evening all.
Just thought I'd let you know that everything is okay now:
Could a member of PN staff cancel the ticket that I posted on the fault system.
Thanks for everyone's help.  Smiley
Fixes: 71
Since you raised the fault ticket yourself you should be able to close it by visiting https://www.plus.net/wizard/?p=search, then click Close against the relevant ticket (or click View and click the Resolved button at the bottom).
David
Glad to see everything's working,the ticket's closed too Smiley
bomster
Sorry to be a burden to this forum, but I now have another problem.
I am getting random connection drops: router stays on, lights are green but internet and ADSL lights go off, and my internet connection drops for around 30 seconds.
I'm starting to think this might be hardware issue with my router. What do you guys thing?
If it is, how easy is it for me to get one of the Plus.net routers that I turned down at the start of when I ordered your service.
Many thanks for your ongoing support and help.
Tom
Fixes: 71
That problem could be router related. Trying a different one would be worthwhile.
If you want a TG582n give the CSC a call and ask for one (now should be a good time to call). You will have to pay P&P (£5.99) by credit card, the rest is waived if you agree to stay for 12 months. It should be received in 2-3 days.
David
Fixes: 10
Are the drops associated with making or receiving telephone calls?
bomster
No, I very rarely receive calls on my land line.
Is it worth disconnecting the router and seeing if I get ore stability?
Cheers for your responses.
Plusnet Staff
Plusnet Staff
Fixes: 5
We could try putting Interleaving on to see if that helps stabilise the line for you?
Chris Pettitt
Cloud Environments Engineer
bomster
Hi Chris.
Yes, could you switch it on.
If it kills my ping, can I request to have it switched back off easily enough?
Cheers.
Plusnet Staff
Plusnet Staff
Fixes: 5
Yes, it shouldn't hamper your ping too much. If you want it switching off, it'll take us 24 hours that's all Smiley
I'll place an order for you now.
Chris Pettitt
