Bad Upload Performance
- Bad Upload Performance
Re: Bad Upload Performance
27-03-2013 10:13 PM
10 minutes ago my line cut out, internet went off for 30 seconds :(.
Could you swtich interleaving back off please Chris?
I'm going to borrow a router from a friend and see if it's that.
Cheers for your ongoing support.
PS - Been getting this every 10 minutes in CS:GO aswell,
27-03-2013 10:30 PM
Sure, I've just got that order placed for you. It'll take around 24 hours to take effect.
27-03-2013 10:31 PM
Should I just bite the bullet and get a Billion 7800N, do you think this would solve my problems (I wont hold you to it :P)
27-03-2013 10:37 PM
Before you do that, let me give you a ring at some point tomorrow and I'll give the best advice I can. Does that sound like a plan?
27-03-2013 10:39 PM
Will it be okay to ring me in the evening?
I get home from work at about 6:30.
28-03-2013 11:30 AM
28-03-2013 5:26 PM
Cheers
31-03-2013 10:01 AM
BT Engineer has just left and there was a problem with the wiring in my house which has now been sorted.
Many thanks for sorting that out, and saving me £95 in the process!
My router is now syncing at 19007 Kbps download, and 1139 Kbps upload which is a nice improvement from before.
My profile with you is still set at 16.2 Mb, could you please update bump/update it?
Many thanks for your support, and a big thanks to everyone in this great forum.
I am amazed by the level of customer service. Brilliant.
31-03-2013 10:08 AM
Pleased to hear this sorted you out
I've bumped up your speed profile to match your sync. Saves you waiting till Monday/Tuesday when DCT are back in
Enjoy the rest of your day, and your new found speeds
Regards,
Matt
31-03-2013 10:13 AM
Cheers for doing that so quickly! I just did a speedtest and I'm still sitting at 15Mbps? Will it take a little while to kick in?
Also, incase it's of any relevance:
What's the reason behind my attainable rate being 22132 Kbps and my actual rate being 19007 Kbps? (I'm not complaining, just interested)
Thanks again.
31-03-2013 10:19 AM
But, the speed profile change usually takes 20-30 minutes to go through, you'll notice a PPP/Sync drop, when it comes back up, the new speed will be applied
Regards,
Matt
31-03-2013 10:24 AM
Cheers
31-03-2013 11:13 AM
Still not 19Mbps. However, I will wait a few days as the BT Engineer said my line is back in 'training' so maybe it will go up over the next few days.
Cheers
31-03-2013 11:19 AM
Quote from: bomster Still not 19Mbps. BT Engineer said my line is back in 'training'
Just had a look for you and the "Administrative" reset has been completed, so running on the new connection profile. Lets see what happens with the "training" period
Regards,
Matt
31-03-2013 11:32 AM
It's worth remembering that the harder you push the line the more errors will occur; errors mean retransmits which reduces the actual speeds you get. Given the choice of a good speed on a stable line with few errors or excellent speeds on an unstable line with many errors I'd choose the former every time. I'm hoping to get a stable line with a 6000 IP profile which is more than adequate for HD streaming (I'm not far off that if they could just stop it dropping on an incoming phone call).
