BT Speedtester
- BT Speedtester
BT Speedtester
17-10-2008 10:52 AM
Nai
Re: BT Speedtester
17-10-2008 11:08 AM
If not, get it here and try the speedtester again.
Re: BT Speedtester
17-10-2008 11:37 AM
Quote from: Paul03 Have you got Java installed?
Well I had a previous version and have installed latest from your link, but no difference - still can't load the tester.
Re: BT Speedtester
17-10-2008 12:09 PM
Which browser are you using? The BT speedtester tends to dislike anything other than IE.
Re: BT Speedtester
17-10-2008 12:26 PM
Re: BT Speedtester
17-10-2008 12:59 PM
I tried every thing
I.E. , Clearing the Cache, deleting all Jave and reinstall, no luck Firefox and I.E. still no luck, tried my Linux baby which used to work, no good.
Two days ago still not working, then yesterday, my XP SP3 laptop worked OK with Firefox. My Linux Baby - Eeepc4g, with "Fixed" operating, still wont run.
Back over to you Orbrey
Re: BT Speedtester
17-10-2008 1:11 PM
My bookmark was pointing to www.speedtester.bt.com (which I'd always previously used) but when I searched the BT site I found it is now http://speedtester.bt.com/ ; - i.e. with no www...
Thanks for the suggestions anyway, at least I got my Java updated!
Nai
Re: BT Speedtester
17-10-2008 1:15 PM
Re: BT Speedtester
17-10-2008 1:29 PM
But I just tried it - and almost fell off my seat when - on the second attempt it worked, telling me my prile was 7150 kbps and actual throuput was 6682kbps
Re: BT Speedtester
17-10-2008 4:34 PM
I am using an iMac running OS X 10.3.9 Panther and get the following responses on the browsers detailed below:-
Internet Explorer 5.2 - Java plugin General Exception
Opera 9.5 - Simply fails to work and produces no output.
Safari 1.3.2 (v 312.6) - Apple ticker Applet 2 not initiated
Firefox 2.0.0.17 - Java Number format exception
Any advice will be welcomed.
Regards,
Davidhil
Re: BT Speedtester
17-10-2008 4:38 PM
Re: BT Speedtester
17-10-2008 5:25 PM
thread started 3/10 http://community.plus.net/forum/index.php/topic,69047.0.html
Re: BT Speedtester
17-10-2008 5:32 PM
Quote from: pierre_pierre Since it went belly up the general has been the big black top border with a white oblong, the Java symbol appears for a short while then a red X in the top LH corner of the white box
Pierre - that's what I was getting today from my old bookmark until I found the new URL. Is everyone using this one now?
nai
Re: BT Speedtester
17-10-2008 5:46 PM
Test1 comprises of Best Effort Test: -provides background information.
Your DSL connection rate: 8096 kbps(DOWN-STREAM), 448 kbps(UP-STREAM)
IP profile for your line is - 7000 kbps
Actual IP throughput achieved during the test was - 6260 kbps
If you wish to discuss these results please contact your ISP.
allehia
Stupid, why dont they tell people
Re: BT Speedtester
17-10-2008 6:03 PM
Have you tried http://217.35.209.142/ instead? That has always worked for me (momentary glitches notwithstanding).
