BT Speed Tester Not Working?
- Re: BT Speed Tester Not Working?
06-02-2011 10:16 AM
Any one else having problems with the BT Speed Tester at:
http://speedtester.bt.com/ ?
All I can get is result below
Message 1 of 8
(1,900 Views)
7 REPLIES 7
06-02-2011 10:25 AM
It's working for me as far as the 'checking user' stage.....but I see it's changed with an extra link for FTTP customers. When did that happen
Admittedly I don't have reason to visit the BT Tester site very often having a perfectly stable maximum speed line.
Message 2 of 8
(608 Views)
06-02-2011 12:15 PM
Not working for me either. I've tried twice this morning. Using Firefox I see an error message different from yours. It just tells me the test is not possible and to try again later.
- Keith
- Keith
Message 3 of 8
(608 Views)
06-02-2011 12:48 PM
Same here, but with Firefox running on Linux. After entering the phone number, hitting "GO", and waiting forever, I get this:
It changed yesterday.
Quote Test Error
The Performance Tester is currently unable to run a speed test for your broadband connection. Please try again shortly, however if this problem persists, raise the issue with your service provider.
Quote from: Strat It's working for me.....but I see it's changed with an extra link for FTTP customers. When did that happen
Message 4 of 8
(608 Views)
06-02-2011 12:54 PM
I get a quick red flash about Java not installed, then it carries on, before it says System busy try later
Message 5 of 8
(608 Views)
06-02-2011 1:05 PM
Yes, seemed to stop working for me yesterday when the front web page changde. Same error, every time I try
"The Performance Tester is currently unable to run a speed test for your broadband connection. Please try again shortly, however if this problem persists, raise the issue with your service provider."
Message 6 of 8
(608 Views)
06-02-2011 5:12 PM
More or less the same with me. Shows my IP profile, then waits for several seconds and says can't complete the test.
Message 7 of 8
(608 Views)
07-02-2011 2:53 PM
Replied to a similar thread about this earlier on today.
Message 8 of 8
(608 Views)
