Is the noise margin bad?
- Is the noise margin bad?
06-02-2011 10:56 PM
I'm getting download speeds of 7Mbps which actually isn't that bad, but as I only moved house 500 yards where I was getting 17Mbps I'm wondering if my line has a problem somewhere?
ADSL Link Downstream Upstream
Connection Speed 16372 kbps 447 kbps
Line Attenuation 21.0 db 11.0 db
Noise Margin 6.3 db 21.7 db
Message 1 of 5
(916 Views)
4 REPLIES 4
Re: Is the noise margin bad?
06-02-2011 10:57 PM
What does this say https://portal.plus.net/my.html?action=data_transfer_speed
Message 2 of 5
(378 Views)
06-02-2011 11:33 PM
Phone exchange:
HIGHBURY
Estimated line speed:
7Mb (This may vary between 10Mb and 19.5Mb) - Checked on 2011-01-11 12:04:58
Current line speed:
15 Mb
HIGHBURY
Current line speed:
15 Mb
Message 3 of 5
(378 Views)
07-02-2011 12:14 AM
Have you tried disconnecting from Plusnet then reconnecting using the router's admin pages (no need to restart the router / re-sync)?
David
Message 4 of 5
(378 Views)
07-02-2011 3:26 PM
Hi RichGK,
From what I can see the order isn't complete yet. Although you might be connected the BT system will not be registering any connection speeds until it's complete.
Jojo
Jojo
Message 5 of 5
(378 Views)
