Asus N66U Users Thread
- Asus N66U Users Thread
Re: Asus N66U Users Thread
05-11-2013 3:30 PM
05-11-2013 3:56 PM
Is it safe enough to just let it auto update the firmware, then? (bear in mind that I'm coming from a 7800N, which is advisable to factory reset after every flipping firmware upgrade!)
05-11-2013 5:10 PM
08-11-2013 10:42 PM
My Raspberry Pi (via a cheap WiFi dongle which is the major bottleneck) was getting ~400KBps throughput on the local network before, which was just about good enough for streaming SD content, but now gets ~1.3MBps which should be good enough for typical HD content. On the default cache settings it's gone from 30+ seconds to starting to play a file to less than 10 seconds, so double winner!
Setup was a doddle and it was up and running in a matter of minutes - the only slight delay was updating the firmware at the start!
10-11-2013 2:03 PM
My wireless speed with my 80/20 broadband connection was limited to 50Mb in download with the PN router and now I get 73 MB without any pb!
So very pleased, no doubt.
In a way that's normal, you cannot expect much from the PN router which comes almost for free....
11-12-2013 12:28 PM
Have an Asus RT-N66U with the latest Merlin build with PPPoE Connection and download speeds of about 70mbps.
Using OpenVPN with provider's desktop client software speed drops to around 35mbps. Not a problem.
I wanted to slot in a dedicated modem and use the Asus for OpenVPN so that all of my wireless and ethernet connections would be covered.
However, when I put in a Netgear N150 WNR1000 and set up the Asus OpenVPN Client, download speed dropped to 12-15mbps.
Connection set up is: Openreach to Netgear WAN, Netgear LAN to Asus WAN with IP phone and other peripherals plugged into Asus.
Any thoughts and suggestions would be welcome.
Paul
13-12-2013 12:22 AM
13-12-2013 10:04 AM
Quote from: purleigh
Having recently researched which routers work best with IPv6, I was gob-smacked to discover that the standard Asus firmware for the N66U exposes your local network to any IPv6 traffic on the internet, as there is no IPv6 SPI firewall, and tests have shown that incoming IPv6 traffic can pass straight through !
The dangers of using a router that is transparent to IPv6 because of the lack of a stateful firewall, are well documented.
Here are a couple of examples - http://www.techrepublic.com/blog/it-security/ipv6-oops-its-on-by-default/, and http://gcn.com/articles/2013/08/09/ipv6-attack.aspx.
I couldn't believe how irresponsible Asus are for shipping a premium product with a massive security issue.
Oooooh! I bought the N66U just this week, still to put into use but at this stage for the record I have disabled IPv6 in the TCP/IP network adaptor settings which as far as I know is by default 'turned on'.
Edit ~ having said that is IPv6 enabled or disabled by default in the GUI of the N66U This suggests disabled...................................goes off to see if PN are using IPv6 now???
13-12-2013 11:42 AM
Quote from: shekinah Any help would be appreciated. (just a little bump!).
http://forums.smallnetbuilder.com/showthread.php?t=12315
13-12-2013 2:39 PM
14-01-2014 6:41 PM
ASUS RT-N66U Firmware Version 3.0.0.4.374.2050
I'm still running stock firmware Version:3.0.0.4.260, as they say, if it ain't broken don't fix it.
But it's been some months now, since i got the RT-N66U, if anything goes wrong i can always go back and use my plusnet supplied router.
14-01-2014 6:49 PM
14-01-2014 7:53 PM
I am waiting for the next wireless driver update as I seem to have lost some of my wireless speeds in the last couple of updates.
17-01-2014 6:17 PM
The plusnet technicolor had a nice and clear "disconnect" button, this does not!
17-01-2014 6:29 PM
Go to WAN > Enable WAN: No > Apply Settings
Or
Click the Green Computer Icon on the top right where it says Connected and it will disconnect. You need to go to the Enable WAN page to reconnect.
