reset line please help
grahamaikman
hi, i should be sitting at about 4meg, currently running around 2meg. it happens intermittantly, when i'm messing with my router config, switching it on and off again, and testing diferent configs out.
could someone please reset the line for me to push me back up to 4meg again. i think it figured i was having line problems and throttled the line.
6 REPLIES 6
Fixes: 160
Re: reset line please help
Hi Graham,
A warm welcome to the forums.
Before anyone goes and resets your line, for you to wait 10 days and then find that you still have problems, can you please take a look at the speed issues thread and post the requested information.
Kevin
grahamaikman
Fixes: 160
Whikst the SNRM is very high, it is sitting at an odd value possibly suggesting that there might be (or has been) some interference on your line.  Your line ought to synch at over 5Mbps, so if it usually sat around 4 it was not performing as expected.
A reset might need to be followed up with further investigation.
grahamaikman
Are you able to reset the line?
Graham.
Chris
Legend
Fixes: 169
Your line looks quite stable, however there are a few errors showing. I've requested a reset for you,
grahamaikman
thanks man. Appreciated!
G
