Asus N66U Users Thread
- Re: Asus N66U Users Thread
26-04-2014 11:43 AM
Quote from: tijara33 If you want something really fast then buy the RT-AC68U.
http://www.trustedreviews.com/asus-rt-ac68u-802-11ac-router_Peripheral_review
No mention of VDSL support though?
26-04-2014 12:10 PM
For an integrated VDSL modem, you need to look at the DSL-xxxx range - e.g. DSL-AC68U.
28-04-2014 9:10 PM
I received this router today to swap out the Technicolour, so need to set it up and I'm not the most savvy when it comes to networking. Should I just follow this instructions in the set up guide manual or does anyone have a link where the instructions may have been recorded in layman's terms?
Thanks in advance!
28-04-2014 9:12 PM
There's an automated set up which will take a couple of mins and get you online. After that, there are lots of different settings/configurations you can use depending on what you want to do.
28-04-2014 9:15 PM
28-04-2014 9:33 PM
When you switch on the router and it goes into installation mode, it will automatically set up an open wireless network for you to join without a password. You join this network and then go to http://192.168.1.1 and admin/admin.
Part of the setup will then be to configure the SSID and wireless security (password etc.).
28-04-2014 11:05 PM
29-04-2014 6:32 AM
Quote Do I need to get my SSID from PN or is this user defined?
You use which ever SSID you decide on. I use my christian name + plusnet + either 2.4 or 5 Ghz to easily differentiate between the 2 frequencies. You also choose your own passwords which are obviously case sensitive.
Like you I know very little about routers & as Andy said, I found setting up my RT-N56U incredibly easy. It has the same GUI as the 66. Good surfing.
29-04-2014 7:44 AM
e.g. "69RhubarbStreet"
That way your immediate neighbours can easily avoid using the same channels you are on, because it is obvious where the broadcast SSID is coming from.
29-04-2014 1:35 PM
11-06-2014 1:00 PM
18-06-2014 9:19 AM
Quote from: bobboulby
Quote from: Hiijinx Will I be able to view stats such as noise margin and errors etc or do I need a router with built in modem to cut out the Open reach box completely ?
I can't speak for the Openreach modem but in my set-up I use a Netgear DG834G in modem only mode. Normally I can't see the Netgear at all so I can't get to the line stats. It is possible however to connect to directly the Netgear using an Ethernet cable and then I can get to the Netgear web interface.
Bob
Hi bobboulby.
I know this is an old post but hopefully you still read it! Can you tell me how you do this? I have exactly the same setup (only with a DG834PN) but when I connect an ethernet cable to one of the LAN ports on the Netgear I cannot access the web interface. I type in the default address but the page won't connect. Am I missing a simply trick?
18-06-2014 1:33 PM
Bob.
18-06-2014 1:38 PM
thank you for getting back so quick. I'll keep plugging away as if it worked once then there's hope! I'm no expert but one issue I can see is if the router is handling DHCP and the modem just passes through then it wouldn't have an IP address surely? Or have I misunderstood that?
shure
18-06-2014 1:55 PM
Bob
