Asus N66U Users Thread
- Asus N66U Users Thread
Re: Asus N66U Users Thread
28-01-2014 11:34 AM
I have a Technicolor TG582n and I'm trying to connect a new Asus RT-N66U for better WiFi. This is my setup (Powerline is TP-Link ethernet-over-power adapter, they are transparent)
This is what I had:
[tt]ADSL > TG582n > Powerline -...-> Powerline --> PC[/tt]
This is what I want:
[tt]ADSL > TG582n > (WAN port) RT-N66U (LAN port) > Powerline -...-> Power line --> PC[/tt]
This is the only thing that seems to work:
+---> (WAN port) ASUS RT-N66U
[/tt]
I've tried lots of ways to connect the RT-N66U to the LAN, but when it tries to automatically detect the internet connection, it says that there is a duplicate use of 198.162.1.1, reconfigures and then disappears from the network. The only way to recover is factory reset.
Can anybody help?
28-01-2014 12:14 PM
Do you want to use the RT-N66U as an access point or as a router (using your TG582N as a modem only in bridge mode)?
28-01-2014 12:20 PM
Quote from: AndyH Do you want to use the RT-N66U as an access point or as a router (using your TG582N as a modem only in bridge mode)?
As a router.
28-01-2014 12:29 PM
Have a look at this thread: http://community.plus.net/forum/?topic=105753.msg902252
You need to configure the TG582N first.
28-01-2014 1:56 PM
Quote from: AndyH This is going to be tricky...
If I do this and it goes horribly wrong, is it easy to reset the TG582N to default settings?
28-01-2014 2:11 PM
And, as a bonus, it seems a touch faster when running a speedtest - like I was at the top end of what a Thompson would handle, before I was getting around 60-65Mb/s, now with the N66U...
<a href="http://www.speedtest.net/my-result/3264948617"><img src="http://www.speedtest.net/result/3264948617.png" /></a>
28-01-2014 2:18 PM
Quote from: Moose666
Yes, I believe so. It is probably worth double checking though or saving your settings first.
08-03-2014 10:30 AM
sorry to butt in on this thread but I have had it bookmarked for a while with the wish of getting rid of PN's 2 piece's of junk they give away.
So,
I have FTTC with an Openreach router feeding into a tg582n giving currently a 73 up/14 down with a ping of 27
I assume the full code for this router is the Asus RT-N66U ?
Will this be compatible with my feed and will it allow me to ditch the Openreach router as well as the Thomson?
Is this thing fairly easy to set up from the box?
Finally, this thread is reasonably old and technology marches on. So are there any other branded routers for the £100ish mark that could be a viable or better alternative?
Much obliged for your time
Steve
08-03-2014 11:47 AM
Not sure about your last question, sorry.
Bob
08-03-2014 5:30 PM
23-04-2014 9:15 PM
26-04-2014 9:08 AM
Thanks.
26-04-2014 10:21 AM
It doesn't support the OSX file system (HFS+) - http://event.asus.com/2009/networks/disksupport/
I would just format the USB stick is FAT32, which will then work with your Mac and Asus.
26-04-2014 11:20 AM
Looking online it seems that the DSL-N66 has a modem - is this suitable for FTTC or only ADSL?
26-04-2014 11:38 AM
http://www.trustedreviews.com/asus-rt-ac68u-802-11ac-router_Peripheral_review
