Advice please.
FIXED- Subscribe to RSS Feed
- Re: Advice please.
29-01-2022 11:09 AM
Fixed! Go to the fix.
on
30-01-2022
11:49 AM
- last edited on
31-01-2022
9:32 AM
by
Hey @Steveo100
Thanks a lot for getting in touch and I'm really sorry to hear that you're having issues with your broadband service. I've run some tests on the line and can see that cross talk has been detected, which might be the route cause for the problems you're having. This has resulted on the profile on the line being banded too, it's now: Downstream: 0.128M-27.4M with Retransmission (High). Upstream: 0.128M-10M with no error protection which is likely due to a drop on the line which occurred on 25/01/2022.
This doesn't quite explain why you're unable to access your Hub Manager though, especially with the Plusnet Hub One. Are you typing 192.168.1.254 into the URL bar on your browser while connected to the router?
Moderators Note: Date corrected
Re: Advice please.
30-01-2022 8:34 PM
Re: Advice please.
31-01-2022 4:21 AM
it's now: Downstream: 0.128M-27.4M with Retransmission (High). Upstream: 0.128M-10M with no error protection which is likely due to a drop on the line which occurred on 25/05/2022.
So Plusnet can see what's going to happen on 25th May 2022?
Re: Advice please.
31-01-2022 8:25 AM
Re: Advice please.
31-01-2022 11:21 AM
Now that you've managed to get onto your Hub Manager @Steveo100, I've gone ahead and have requested a DLM reset on your line, to squeeze out more Mbps. Hopefully this improves your overall connection. Let us know if you have any further issues going forward though. ![]()
Re: Advice please.
01-02-2022 2:08 AM
@adam945 Ok thanks for this, internet still dropping btw. Unless you know different, I assume pn still use the Hub one for the unlimited fibre contract ? Tia.
Re: Advice please.
01-02-2022 4:37 PM
Hi @Steveo100, thanks for getting back to us. I am sorry for the drops you are having, these do look quite frequent so we may need to look at sending an engineer. I have created a fault ticket here with the next steps and if you give us a nudge if you add a reply, we can pick that up for you: https://www.plus.net/wizard/?p=view_question&id=221635129
The Hub One is still widely in use though we now have the Hub Two available. This is currently available for customers renewing their contract or new customers.
