Advice please.
Steveo100
Advice please.
Hi, I'm banging my head on this, hope someone can help. Have had a Bt hub 6 working ok for at least 12 months. Suddenly no internet and an orange light. Have reset hub, and plugged in a land line phone, (mk4 BT master socket 5C) which has a dialing tone. Have also tried two other hubs including the pn hub 1. I also cannot access the home hub manager ! Just won't connect either the Bt or Pn page . I haven't a lap top or pc to connect via ethernet, as just use iPad and Android phone. Stumped as to what to do next. Tia
7 REPLIES 7
adam945
Fixes: 113
Re: Advice please.
Hey @Steveo100
Thanks a lot for getting in touch and I'm really sorry to hear that you're having issues with your broadband service. I've run some tests on the line and can see that cross talk has been detected, which might be the route cause for the problems you're having. This has resulted on the profile on the line being banded too, it's now: Downstream: 0.128M-27.4M with Retransmission (High). Upstream: 0.128M-10M with no error protection which is likely due to a drop on the line which occurred on 25/01/2022.
This doesn't quite explain why you're unable to access your Hub Manager though, especially with the Plusnet Hub One. Are you typing 192.168.1.254 into the URL bar on your browser while connected to the router?
Moderators Note: Date corrected
 Adam
 Plusnet Help Team - Leeds
Steveo100
Re: Advice please.
Hi Adam, thanks for your reply. Not sure what all the technical jargon means though 😆 ,The Hub one, just fired into action 🤷, and was then able to access the manager, surffice to say, this hub isn't as stable as the Bt hub6. Will maybe try the Bt hub another day. Are Pn still using the hub one ? As I have to renew my contract in March, we are on the unlimited fibre package atm. Tia.
Tags (1)
Shep41
Seasoned Pro
Fixes: 7
Re: Advice please.
@adam945. Plusnet now predict the future?
it's now: Downstream: 0.128M-27.4M with Retransmission (High). Upstream: 0.128M-10M with no error protection which is likely due to a drop on the line which occurred on 25/05/2022.
So Plusnet can see what's going to happen on 25th May 2022?
adam945
Fixes: 113
Re: Advice please.
Whoops, that was supposed to say 25/01/2022 😂 - my bad, I’ll see if I can get that changed haha!
 Adam
adam945
Fixes: 113
Re: Advice please.
Now that you've managed to get onto your Hub Manager @Steveo100, I've gone ahead and have requested a DLM reset on your line, to squeeze out more Mbps. Hopefully this improves your overall connection. Let us know if you have any further issues going forward though. Smiley
 Adam
Steveo100
Re: Advice please.
@adam945 Ok thanks for this, internet still dropping btw. Unless you know different, I assume pn still use the Hub one for the unlimited fibre contract ? Tia.
LaurenB
Fixes: 131
Re: Advice please.
Hi @Steveo100, thanks for getting back to us. I am sorry for the drops you are having, these do look quite frequent so we may need to look at sending an engineer. I have created a fault ticket here with the next steps and if you give us a nudge if you add a reply, we can pick that up for you: https://www.plus.net/wizard/?p=view_question&id=221635129
The Hub One is still widely in use though we now have the Hub Two available. This is currently available for customers renewing their contract or new customers.
 Lauren Barry
