ADSL connection speed varies enormously many times a day
- Re: ADSL connection speed varies enormously many t...
- « Previous
- 1
- 2
- Next »
Re: ADSL connection speed varies enormously many times a day
25-10-2012 2:41 PM
I have a Plusnet-supplied Thomson TG 585 v8.
Bert
Bert
Message 16 of 22
(312 Views)
25-10-2012 2:48 PM
Perhaps someone familiar with that router could say if it has an idle timeout setting.
What version of the firmware do you have on that? I'm wondering if you need an update.
Message 17 of 22
(312 Views)
25-10-2012 2:56 PM
I just checked, and I have firmware 8.2.7.8 which I believe is the latest version. I can't see any information about an idle timeout setting. And actually, thinking about it, the connection has been idle for lengthy periods in the past without dropping the line, so I rather doubt if that's the problem.
Bert
Bert
Message 18 of 22
(312 Views)
25-10-2012 5:00 PM
Yes, 8.2.7.8 is the latest TG585v8 software.
There might be an idle timeout setting somewhere in the CLI but I'm fairly sure it doesn't appear on the GUI. My settings are default and I don't get disconnections.
David
Message 19 of 22
(312 Views)
31-10-2012 1:36 PM
This problem seems to be getting worse, with disconnections/extreme speed drops happening more and more frequently.
I was thinking that I could live with it until I change to fibre (in two weeks time) but I was wrong. So I'll take the advice offered here and try a different router.
Bert
Bert
Message 20 of 22
(312 Views)
02-11-2012 11:26 AM
If that doesn't fix the issue then raise a fault for us to look at https://faults.plus.net
Message 21 of 22
(312 Views)
02-11-2012 11:32 AM
I'll do that, thanks.
Bert
Bert
Message 22 of 22
(312 Views)
- « Previous
- 1
- 2
- Next »
