Static IP...
- Static IP...
Static IP...
01-11-2012 1:40 PM
Having just activated the Static IP for my account I noticed the following message at the bottom of the page:
These days with routers already having some form of Firewall included and the fact that, I suspect, most people are connected permanently anyway with router reboots less frequently than ever before is there really any perceived increase risk in security vulnerabilities more than with a dynamic IP?
Edit: Also bear in mind the basic firewall with XP and the more advanced ones with Vista/W7 (have no idea about w8).
Quote Please note: Having the same IP address each time you connect may expose you to security vulnerabilities and we recommend that you install Firewall software such as ZoneAlarm.
Forum Moderator and Customer
Message 1 of 4
(683 Views)
3 REPLIES 3
Re: Static IP...
01-11-2012 2:43 PM
My view is that yes there may be a slightly added risk which is why that message is displayed.
With regards to using a software firewall they tend to provide a different level of protection to that of a hardware firewall so I would personally advise using both and think of the software firewall as a second line of defence.
Message 2 of 4
(336 Views)
Re: Static IP...
01-11-2012 2:52 PM
Thanks for the reply, Adam.
I hope you didn't misunderstand my reason for asking.
I know there is always a need for good security just felt unsure that the risk is any greater these days with Static IPs and good Firewalls.
Of course, if someone doesn't use a firewall...
Message 3 of 4
(336 Views)
Re: Static IP...
02-11-2012 11:35 AM
Hi Mav,
I don't believe there is any greater risk these days, it's just the fact that you will not change IP address whereas when you having an IP address changing whenever you have a drop in connection can be potentially harder to track.
Saying that as long as you have your hardware and software firewalls are up-to-date you would be at no greater risk than anyone one else.
Message 4 of 4
(336 Views)
