ADSL -Slow upload speed and ERR_SSL_BAD_RECORD_MAC_ALERT
FIXED- Subscribe to RSS Feed
- ADSL -Slow upload speed and ERR_SSL_BAD_RECORD_MAC...
29-11-2023 5:32 PM
For about 4/5 days now we have been getting intermittent ERR_SSL_BAD_RECORD_MAC_ALERT when we access various websites. Across multiple device (phone/laptops) using Wifi / Ethernet - also occurred when everything disconnected and wifi disabled with one laptop ethernet straight to the router.
We only have ADSL here no fibre but consistently get 12-14 Mbs down and just under 1 Mbs up. Recently various speed checkers are giving only around 0.1-0.2 Mb/s up.
Contacted support on Monday and tested giving line fault. Openreach out today and replaced the master socket and claimed no fault and testing good. However we still have both ERR_SSL_BAD_RECORD_MAC_ALERT and slow upload. Strangely the router reads 1.107 up which is very different to any speed test. I can't find any detailed noise stats in the router pages but later I may switch back to an old BT hub one to check if this gives more detail.
Router Connection Information - DSL Line Status
| Line state: | Connected |
| Connection time: | 0 days, 08:28:07 |
| Downstream: | 18.8 Mbps |
| Upstream: | 1.107 Mbps |
Fixed! Go to the fix.
Re: ADSL -Slow upload speed and ERR_SSL_BAD_RECORD_MAC_ALERT
29-11-2023 7:10 PM
Hi @batesi I'd definitely try another router to see if you get the same error. That one can crop up if the MTU isn't set correctly.
29-11-2023 7:16 PM
29-11-2023 9:56 PM
1. Product name: Plusnet Hub
2. Serial number: +081441+NQ13349066
3. Firmware version: Software version 4.7.5.1.83.8.289.1.3 Last updated 27/01/22
4. Board version: Plusnet Hub One
5. DSL uptime: 0 days, 00:29:33
6. Data rate: 1119 / 18981
7. Maximum data rate: 1104 / 19056
8. Noise margin: 6.3 / 3.1
9. Line attenuation: 9.8 / 23.6
10. Signal attenuation: 10.2 / 21.6
11. Data sent/received: 29.2 MB / 764.9 MB
12. Broadband username: [email protected]
13. 2.4 GHz Wireless network/SSID: PLUSNET-R586
14. 2.4 GHz Wireless connections: Enabled (802.11 b/g/n (up to 144 Mb/s))
15. 2.4 GHz Wireless security: WPA2
16. 2.4 GHz Wireless channel: Automatic (Smart Wireless)
17. 5 GHz Wireless network/SSID: PLUSNET-R586-5G
18. 5 GHz Wireless connections: Enabled (802.11 a/n/ac (up to 1300 Mb/s))
19. 5 GHz Wireless security: WPA2
20. 5 GHz Wireless channel: Automatic (Smart Wireless)
21. Firewall: Default
22. MAC Address: 10:d7:b0:4a:cc:ee
23. VPI/VCI: 0 / 38
24. Modulation: G.992.5 Annex A
25. Latency type: Fast
26. Software variant: AA
27. Boot loader: 1.0.0
30-11-2023 10:16 AM
Ah no!! What a pain @batesi
As you have tried several routers that rules that out. I have researched it and there is an article here: https://kinsta.com/knowledgebase/err_ssl_bad_record_mac_alert/ with more suggestion to find the cause.
I'd start with trying an alternative browser.
Let me know how you get on.
30-11-2023 5:22 PM
30-11-2023 5:55 PM
30-11-2023 6:10 PM
01-12-2023 12:09 PM
Has the engineer been yet @batesi ? There's no notes about it yet but just want to check with you.
04-12-2023 11:37 AM - edited 04-12-2023 11:38 AM
So on Friday morning before the Engineer visited the fault seemed to clear - upload speeds also improved - up to 0.8 Mbs (unseen for a week).
Anyway not unexpectedly the Engineer couldn't find any line error. However on discussing with him he was of the opinion that Power Line converters could cause interference with the modem/router. Now - I've been using these for several years without major issue - but I decided to eliminate this as a possible issue. I've added a more powerful TP link router as my main WIFI access point so I don't need powerline converters.
Anyway as I said things have improved - the line upload speed still varies quite a bit but I think its to be expected - I've a mile of copper to the exchange.
The ERR_SSL_BAD_RECORD_MAC_ALERT - I have actually seen a couple of times over the weekend - It could be this one just another unrelated issue - I will see how it goes.
15-12-2023 11:33 AM - edited 15-12-2023 11:35 AM
@adamwalker other routers have been tried, MTU is 1500, ADSL connection looks OK but upload bandwidth is restricted somewhere - do you have any other ideas ?
See continuation of this topic here - ADSL ERR_SSL_BAD_RECORD_MAC_ALERT error
15-12-2023 11:36 AM
