ADSL ERR_SSL_BAD_RECORD_MAC_ALERT error
batesi
I posted about this previously but unfortunately it's still an ongoing issue for us. We are still getting this error at multiple websites along with many disconnections.
Each time we've had a disconnection the robot has detected a line fault. So far we have had 3 visits from Openreach and two different master sockets, circuit tests, replaced part of outside wiring connections. Since the last visit today we had no disconnections but the ERR_SSL_BAD_RECORD_MAC_ALERT persists across multiple browsers, windows, android. Firefox doesn't show this error but I've seen a similar secure connection failed error.
I've tried 4 different routers including a second hand draytek router I picked up on eBay - same issue. We also replaced all powerline converters at one OpenReach engineers recommendations.
64 REPLIES 64
Re: ADSL ERR_SSL_BAD_RECORD_MAC_ALERT error
So if I've got this right, you have four routers available to experiment with
    1)  Plusnet Hub 1
    2)  BT hub
    3)  DrayTek  ? ? ?
    4)  TP-Link   ? ? ?
What are the model numbers of the DrayTek, and the TP-Link  ?
Which router is currently connected to the internet ?
Do you have a landline phone plugged in, and does it get used ?
Is the router plugged in to the master socket DSL outlet using a short cable ?
Is there any telephone extension wiring from the master socket to other slave sockets in your house ?
@batesi
This might be helpful?
https://www.ssldragon.com/how-to/fix-ssl-errors/fix-err-ssl-bad-record-mac-alert/
If that link doesn't work then try a search on "ERR_SSL_BAD_RECORD_MAC_ALERT"
batesi
Because of the errors/slowness I get its actually tough to post on this forum - its taking forever to load!
My kids would say this is "laggy"
Failed to load resource: net::ERR_HTTP2_PING_FAILED - these errors appear in chrome dev console.
Actually 5 Routers/Hubs in total
    1)  Plusnet Hub 1
    2)  BT hub - smart hub type A
    3)  DrayTek  - Vigor 2760
    4)  Sagecom 2704n
TP-Link   - Archer C80 AC1900 - no modem used as Wifi Access point as Plusnet hub wifi is inadequate. Its connected via ethernet cable direct to the plusnet hub (acting as modem).
Which router is currently connected to the internet ? Plusnet (as a modem) uplink to Tplink
Do you have a landline phone plugged in, and does it get used ? I've unplugged it and it makes no difference. In fact its been unplugged most of the last week.
Is the router plugged in to the master socket DSL outlet using a short cable ? Yes - also the master socket is a new one with integrated filter - i.e. Openreach supplied. Its got a separate phone and modem socket.
Is there any telephone extension wiring from the master socket to other slave sockets in your house ? No they've all been disconnected since the first engineer visited.
Fixes: 385
What computer/ laptop are you using, how old is it and what operating system/browser?
@batesi
For your devices are all the operating systems and applications up to date?
Turning off DHCP or Wireless does not make the Hub One act as a modem, it still has an active router. Any router connected to the Hub should be connected in Wireless Access Mode.
On the Hub, navigate from the Home Screen to Troubleshooting > Helpdesk and post a screen shot, make sure you redact your broadband username. This will detail you broadband connection speed and line stats
Post deleted !  -  I had assumed that a Hub 1 can be put in 'bridge' mode, but apparently can't !
batesi
Problems on multiple browsers/laptops/phones:
  • Work laptop Dell Precision 7750 - Windows 10 Enterprise - 2yrs old, Chrome, Firefox, Edge
  • HP Spectre 360 - Window 11 - 2 yrs old, Chrome
  • Pixel 6 pro - Android 14 - Chrome, Firefox, Kiwi etc
  • Nokia 8 - Android 9?
  • iPhone 13 mini - Safari - my wife reports slowness and problems
I've tried plugging the Dell direct into the Plusnet hub - same errors. I  can try this again but not till later! HP has no ethernet port so would need a USB 3 adapter to try that.
batesi
see other posts
What firmware does the DrayTek Vigor 2760 have installed ?
I'm thinking that this modem/router does support 'bridge' mode (i.e. the routing features are bypassed), and from the kit you have to hand is probably the best candidate to be configured as a simple modem, with a view to using that in place of your Hub 1, and use the TP-Link as your router+WiFi
I suspect the likely reason for your various SSL errors will be "Double NAT" caused by having two routers wired in series.
batesi
Its got the latest firmware available but not its end of life so no firmware past late 2022. 3.8.9.6 BT
The reason I'm not using it now it as suspected it was causing instability (or not improving things)
TP-Link is configured as Access Point - according to all documentation this setup should work with any modem/router.
I disagree:
  • same issues plugging straight into the Plusnet hub (or whatever modem / router I use) if I disconnect the TP lInk.
  • same errors if I switch back to Plusnet wifi and use it as supplied (or if I connect direct to ethernet - given I can only do this with Dell Laptop).
  • same errors connected directly to draytek, bt or sagecom 2704 router.
OK,  with the additional info about your setup, I don't disagree with your replies.
Since the engineer visit yesterday, would you say that your ADSL line is stable ?
Can you post the Hub 1 ADSL line stats, as requested in Reply #6 -
@Dan_the_Van wrote:
On the Hub, navigate from the Home Screen to Troubleshooting > Helpdesk and post a screen shot, make sure you redact your broadband username. This will detail your broadband connection speed and line stats
Have you at some point used the Pixel 6 as a mobile data hotspot and connect your two PC to that? If you have, does the reported issue go away?
batesi
Yes I do that - it's the only way I can do my job when my connection is bad.... I'm a software developer. I tend to use my work iPhone as a hotspot
As some of the online solutions for  ERR_SSL_BAD_RECORD_MAC_ALERT  suggest that sometimes it is due to a misconfigured MTU,
Can you test your connection using this tool -  SpeedGuide : TCP Analyser
and then copy/paste the results from the subsequent "Share Your Results" box
