*21CN ONLY* Do you think your PN profile is not updating as it should?
- Re: *21CN ONLY* Do you think your PN profile is no...
Re: *21CN ONLY* Do you think your PN profile is not updating as it should?
05-04-2012 4:47 PM
IP Profile for your line is - 13.92 Mbps
@ Jo update - seems as though whatever was causing my speed problem has been rectified by the new training period you sorted / or settings ? , training finished now couple of weeks or so back been obviously much faster than its stuck 2mb for a good while now so happy so I shant need to go ahead with booking engineer call it seems now so thanks for whatever setting etc sorted it
09-04-2012 8:27 AM
The current router stats shows as:
ADSL Link / Downstream / Upstream
Connection Speed / 11732 kbps / 1199 kbps
Line Attenuation / 38.5 db / 19.7 db
Noise Margin / 6.1 db / 6.0 db
Using Speedtest.net the typical results are
My Plusnet profile as not changed from 6.5 Mb.
It was interesting to note that shortly after I installed the new router I got the results below but 4 hours later I was getting similar result to those above..
10-04-2012 2:17 PM
I've moved your profile up on our side to 13100, you should see this shortly.
Jojo
10-04-2012 2:36 PM
I have raised your profile to 10300 to allow for your new BT IP profile. This should take effect shortly.
Jojo
10-04-2012 5:53 PM
Thank you
11-04-2012 9:40 AM
Thanks - Bob
11-04-2012 12:46 PM
I can now join in contributing to this thread.
I was upgraded to 21CN/ADSL2+ just over a week ago on Tuesday 3rd April
My router has been on 13279kbps sync, and at this speed continuously 24/7 since last Saturday.
The BT speedtester is reporting an IP setting of 11720 as fully expected for this sync' speed.
But my Plusnet IP setting remains at 7150 - which was the old 20CN figure.
So please can it be aligned with the BT speedtester one
11-04-2012 1:05 PM
I have raised your profile to 16200 to allow for your new BT IP profile. This should take effect shortly.
Jojo
11-04-2012 1:08 PM
I've also raised your profile to 11700 to allow for your new BT IP profile. This should take effect shortly.
Jojo
11-04-2012 1:53 PM
Bob
11-04-2012 1:55 PM
it's normally within 12 hours.
Jojo
11-04-2012 2:32 PM
11-04-2012 2:44 PM
I have raised your profile to 8200 to allow for your new BT IP profile. This should take effect shortly.
Jojo
11-04-2012 2:54 PM
About 4 days after my upgrade to ADSL2+ at the end of March the line speed rose to 12.5Mb/s (via speedtest.net & bbc iplayer speed test). It has now dropped to ~6Mb/s. The line is stable though I did reset the modem/router a few times last week following problems with your DNS servers.
Router currently reports:
Upstream 1255800
Downstream 15067500
SNR Margin(Upstream) 7.5 dB
SNR Margin(Downstream) 6.05 dB
Line Attenuation(Upstream) 13.0 dB
Line Attenuation(Downstream) 30.5 dB
CRC Errors(Upstream) 0
CRC Errors(Downstream) 0
Latency(Upstream) Fast
Latency(Downstream) Fast
Can the speed be bumped up please.
11-04-2012 3:05 PM
I have raised your profile to 13200 to allow for your new BT IP profile. This should take effect shortly.
Jojo
