help
- help
help
03-12-2007 11:41 PM
changed filters,cables,modems. and computers still no signal plusnet has done all the checks they say they can . now up to bt to check what else can i do to be sure its not my end . i have moved address it lasted a week before going down . been with plusnet for about 3 years plus, and never had this before .
could it be the move that has caused this hickup. the weather has been bad and i got overhead cables?.
Re: help
04-12-2007 11:11 AM
As long as you have done the following, then I don't think there's much else you can do.
- Changed microfilter
- Connecting to master socket via filter
- All other telephony devices detached
- Tried different modem or router
- Tried using test socket behind master faceplate
Re: help
04-12-2007 4:08 PM
Quote from: Jameseh Hi there,
yes done that and more.
whats the next step and how long.
Re: help
04-12-2007 4:16 PM
I've pushed your fault back to BT and we should have a further update for you in the next 24-48 hours.
Re: help
06-12-2007 9:04 AM
please give me an update
Re: help
06-12-2007 9:20 AM
Is this a constant or intermittent fault? If it's constant, then I think it might be fixed as BTs line checking system is currently showing you as being in sync with the exchange?
Re: help
06-12-2007 10:45 AM
Re: help
06-12-2007 10:56 AM
I'm still seeing your line gaining sync from the exchange.
Can you do me a favour and unplug your modem from the telephone socket?
(Basically so it's impossible for it to receive a signal)
I have a cunning theory...
Re: help
06-12-2007 11:09 AM
Re: help
06-12-2007 11:36 AM
Ladies and Gentlemen, we have a dodgy line card at the exchange.
I'll send this back to BT with notes.
Re: help
06-12-2007 11:38 AM
Re: help
06-12-2007 11:54 AM
in the mean time i shall find a rope and a tree with a strong branch in case all else fails
Re: help
06-12-2007 11:57 AM
Hopefully we should hear back in the next day or so.
Re: help
06-12-2007 12:13 PM
I think one line line card supports connections from multiple users and if the fix involves card replacement it is likely to take place overnight to minimise disruption from disconnections.
I would think you could try connecting later in the day, then perhaps in the morning. If the connection light comes on the problem should be fixed.
Re: help
06-12-2007 12:54 PM
I've just spoken to BT for you and have arranged for a "frames" engineer to go to the exchange to fix the problem.
