help
- help
Re: help
07-12-2007 9:01 AM
still no signal will try later today
Re: help
07-12-2007 9:12 AM
I've just spoken to BT again and asked them to do some further work at your BT exchange. I'll let you know when I've heard something back.
Re: help
07-12-2007 12:49 PM
trying to connect error 721 server not responding.
this is on both computers no software changed.
modem fine , dsl light ok ,
Re: help
07-12-2007 12:56 PM
Are you on a VPN?
Re: help
07-12-2007 1:00 PM
am using dialup to post .this must be plusnets server problem not my end.
Re: help
07-12-2007 1:02 PM
From what I can tell, the work requested to be done now has been. Can you please try rebooting your equipment and then trying to reestablish the connection in your normal fashion. Let me know if you are getting the sync light on your modem (like you were earlier).
Re: help
07-12-2007 1:22 PM
rebooted power light on dsl light on no data light
veriying user name and password
server not responing .
Re: help
07-12-2007 1:30 PM
Please can you try logging on with the test usernames, in this order?
1) username: bt_test@startup_domain
password: test
2) bt_test_user@plusdsl.net
password: test
If both of these work your own username should do, however if you can post the results of all three of these tests (including logging on with your own username and password after you have done the first two) and we'll be able to advise further.
Re: help
07-12-2007 1:51 PM
remote computer did not resond.
no software or hardware changes
Re: help
07-12-2007 1:55 PM
If so, usually in this case this is something (a firewall or antivirus in most cases) on your PC blocking the outgoing connection from the modem; if the connection were getting out you would have a specific server name rather than 'remote computer'.
If not please advise further regarding the error messages received and we will investigate further for you.
Re: help
07-12-2007 2:01 PM
on one computer i have tuned off virus and firewalll
Re: help
07-12-2007 2:29 PM
its strange that i loss broadband 6 days ago because of bt line card fault. now when i got a signal i got 721 there is a connection there somewhere on in my case no connection.!!!
Re: help
07-12-2007 3:15 PM
I've just run a radius log check on this line and no logins were recorded on the exchange equipment, even the test logins. I will add this information to the fault ticket as it could be indicative of a fault at the exchange though it could also mean that the connection is not leaving the PC. Is there any way you could test this issue with a router rather than an ADSL modem?
Re: help
07-12-2007 5:15 PM
and seeing that the line frame was at fault this must be no1 suspect / i cant do no more but try to connect once or twice a day,
Re: help
07-12-2007 5:34 PM
