F9/plusnet unlimated to plusnet premium speeds & traffic shaping
- F9/plusnet unlimated to plusnet premium speeds & t...
Re: F9/plusnet unlimated to plusnet premium speeds & traffic shaping
22-02-2010 12:35 AM
Wireless 802.11b/g ADSL2+ Modem Router with 4 Ports Switch
‧Description:
Full Rate ADSL2+ connection
Supports 802.11b/g Wireless Access Point
Support IP sharing for upto 253 wired / wireless users
Operating modes include routing, bridge, static IP, PPPoE, PPPoA, dynamic IP
Web-Based Configuration and Smart Setup Wizard
Compatible with major operating systems e.g Windows, Mac, Linux
Firmware upgradable
I've done a factory reset & flashed the most recent filmware .
In ADSL mode option it gives these options
Auto sync
ADSL2+
ADSL2
G.DMT
T1.413
G.lite
I've tried ASDL2+ , ADSL2 & Auto Sync
but G.DMT still shows on the line sats
Line State : Showtime
Modulation : G.DMT
Annex Mode : ANNEX_A
Hmm ?
22-02-2010 1:02 AM
However since you've tried all the alternatives it does seem you are stuck with G.DMT at the moment. Do you have an alternative ADSL2+ capable router to try to confirm it isn't a router problem?
22-02-2010 1:08 AM
Just done another another BTspeed test
Download speedachieved during the test was - 4631 Kbps
For your connection, the acceptable range of speedsis 600-7150 Kbps.
Your DSL Connection Rate :6336 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 5000 Kbps
It says max on the line 7150kbps... Could than mean I'm still on normal ADSL ?
Quick look on http://www.kitz.co.uk/adsl/max_speed_calc.php
Gives a line speed of over 9500 on a 39db Attenuation for ADSL2+ ????
While dslMAX is 7100
Thanks again for helping with this ...:)
22-02-2010 1:39 AM
22-02-2010 1:59 AM
Its also being checked with 21CN support so well see how it goes.
Thanks again
f9o
22-02-2010 2:23 AM
22-02-2010 10:34 AM
22-02-2010 10:47 AM
22-02-2010 12:04 PM
We'll see how we go tomorrow
Any insight into why I had a stuck 2mbps profile when the contracts changed over???
Thanks again
f9o
22-02-2010 3:23 PM
Quote from: Force9Original Any insight into why I had a stuck 2mbps profile when the contracts changed over???
It's a common bug that has been affecting people changing products for a long, long time (months if not years). One day they will fix it (Oh look, there's some bacon going past the window!)
22-02-2010 4:04 PM
Makes you wonder how many others have stuck PN profiles and are not even aware of the bug.....
BT speed test
Download speedachieved during the test was - 5017 Kbps
Additional Information:
Your DSL Connection Rate :6496 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
Router line sats
Modulation : G.DMT
Downstream Upstream
SNR Margin : 6.5 25.0 db
Line Attenuation : 41.0 25.0 db
Data Rate : 6496 448 kbps
22-02-2010 8:38 PM
23-02-2010 1:12 PM
From 5am this morning.......
Modulation : ADSL2 PLUS
Downstream Upstream
SNR Margin : 6.2 9.3 db
Line Attenuation : 37.0 25.0 db
Data Rate : 6756 888 kbps
What happens next?
Do I just leave it alone for a few days before trying for a higher sync rate .
Thanks again for the help f9o
23-02-2010 3:38 PM
Please post back if there's anything else we can do for you.
23-02-2010 5:42 PM
Assuming it is significantly above 6dB power down the router, wait 10 minutes then power up again and see what you achieve. Best to avoid further re-syncs though.
