F9/plusnet unlimated to plusnet premium speeds & traffic shaping
- F9/plusnet unlimated to plusnet premium speeds & t...
Re: F9/plusnet unlimated to plusnet premium speeds & traffic shaping
12-02-2010 1:22 PM
Hows the best way to change contracts from f9 unlimited to Premium ?
I'd like to put a side note about the line ,saying it was me checking my sockets/cables that gave the high resyncs.
so when they take a look at my line so it wont affect the IP sats.
(Ticket ID: 31947192 if it helps)
12-02-2010 1:25 PM
You can do this by clicking the upgrade button in the member centre.
You can't put a note in admitting to fiddling with things unfortunately, as line management is automated. A shift to ADSL2+ will reset this for you anyway though so you'll have a clean slate.
12-02-2010 1:35 PM
I'll get my order in before the billing date then
Any idea's on why my Line sats keep changing or is it normal to vary with in a range?
Thanks for all the help
12-02-2010 1:38 PM
12-02-2010 3:13 PM
Mand noted that the recent upgrade has added capacity to 21CN so hopefully there's no more congestion issues.....
Is there any difference in port traffic management between f9 unlimited & Premium ?
Carn't seem to find any f9 contract details anymore....
Very , very consistent speeds the last few days
12-02-2010 8:58 PM
Look forward to see how I get on on 21CN .
I take it I don't need to do anything else....?
Thanks f9o
12-02-2010 9:04 PM
16-02-2010 5:55 PM
( Ring wire picking up electric underfloor heating "noise" even though NTE5 faceplate filter is fitted)
Thanks f9o
18-02-2010 11:36 AM
Just looked at account billing and it say I've been billed £19.99
My exchange says Area 3 so it should be £15.99
Enabled: 2000
Market: 3
If I go in to change products its says
THIS IS YOUR CURRENT BROADBAND PRODUCT
Plusnet Premium£15.99per month
Somethings a miss
(Ticket ID: 31947192 if its helps)
19-02-2010 2:04 PM
19-02-2010 4:33 PM
Tried changing Gateways & carn't find any know issues with the exchange or had warning of the 21cn change over.
Getting good Sync speed just under 6.5mb ?
Line stats
ne State : Showtime
Modulation : G.DMT
Annex Mode : ANNEX_A
Downstream Upstream
SNR Margin : 6.5 25.0 db
Line Attenuation : 40.5 25.0 db
Data Rate : 6464 448 kbps
19-02-2010 7:17 PM
Still only 1.8mb ? ( Kinda now thinking what have I've done changing to Prem with incorrect pricing & poor speed I'm hoping its just coincidence..........
Any ideas ? ?
Nothing showing up on my exchange http://usertools.plus.net/exchanges/
I;m still syncing @ Data Rate:6464 448 kbps
19-02-2010 7:28 PM
19-02-2010 10:54 PM
Has my BRAS Profile been reset to 2mb ????
I don't really want to start re-sync the lines being monitored by bt
SNR Margin : 6.0 25.0 db
19-02-2010 11:02 PM
Estimated line speed:
5 - Checked on 2010-02-19 14:18:08
Current line speed:
2000
