windows 7
- Re: windows 7
- « Previous
- Next »
Re: windows 7
28-10-2009 3:47 PM
Our Andy's put a quick guide to Win7 shortcuts into the Support Library.. check it out:
http://community.plus.net/library/windows/windows-7-shortcuts/
Re: windows 7
28-10-2009 3:58 PM
Quote from: Axisofevil I shall upgrade it over the internet and it will work.
Given that it's off topic for this thread, I won't delve on this point too much... but: You're doing better than me, every major distro upgrade of Ubuntu has left me fighting to get things working correctly again for at least 2-3 days after it.
Particularly the last one that changed the major Perl version (IIRC).
Anyway, back on topic:
Windows 7 Home Premium isntalled on my laptop... and the first thing it needed to do was download ~ 9 critical updates.
I'll install Ultimate on my desktop as soon as I can work out the easiest/best way of getting my documents etc. backed up.
Re: windows 7
28-10-2009 4:17 PM
Very useful
Quote from: Peter Our Andy's put a quick guide to Win7 shortcuts into the Support Library.. check it out:
Now to find out how to disable these stupid shortcuts
Quote Mouse Shortcuts
* Drag window to the top: Maximise the window
* Drag window left/right: Dock the window to fill that half of the screen
Re: windows 7
28-10-2009 8:52 PM
Jim, I use the keyboard shortcuts for this functionality (windoze key + left/right/up) and I find it quite useful. I too wish I could disable the mouse functionality to do the same though so if you find a way then please share it!
Re: windows 7
28-10-2009 9:20 PM
http://www.howtogeek.com/howto/windows-7/disable-the-mouse-drag-window-arranging-feature-in-windows-...
Google is your friend when you know what to ask for
Re: windows 7
28-10-2009 9:25 PM
Sorted! Nice one Jim
Re: windows 7
30-10-2009 5:06 PM
Decided to try an experiment the other night. I've been following the Vista shenanigans for some time now (specially with regards to hardware requirements and support). Just out of sheer curiosity I decided to run Vista Upgrade Advisor. The results were far from as favorable as they were when I ran it a few years back. In a nutshell, "Buy a new PC".
Immediately afterwards I downloaded and ran Windows 7 Upgrade Advisor. This time the results were completely at the other end of the scale. Everything passed except my 7600gt video card and that was only doubtful about running the Aero Desktop.
Go figure.
Go figure.
- « Previous
- Next »
