Unwanted application
journeys
I've downloaded 'kindle for PC' from Amazon, it has come with an additional package called BrowserSafeGuard, anyone know what it does?
3 REPLIES 3
Gus
Re: Unwanted application
Seems to be an enforced proxy which scans all you traffic to block anything suspicious.  But looks to be more of an issue itself, I would kill it.
http://forums.anvisoft.com/viewtopic-45-2510-0.html
FTTP 500 regrade from Tues 28th November
ReedRichards
Seasoned Pro
Fixes: 25
This type of software often accompanies malware that changes your home page and search provider and then blocks attempts to change them back on the pretext of safeguarding your browser settings.
journeys
@Gus, RR: thanks, malwarebytes sorted it out
