Can't access http://imgbox.com
celica2012
Hi, can't seem to access http://imgbox.com or any images hosted on it. Yet according to Is It Down it's just me. Anyone know any reason or a way around it.
5 REPLIES 5
pwatson
Re: Can't access http://imgbox.com
I can't get at http://imgbox.com either but it does work if you use a proxy server such as http://www.kproxy.com/
HTH
ejs
Aspiring Hero
Fixes: 25
I'd guess it's a slight variation on the usual IWF filter problem that has cropped up numerous times in the past.
Unbelievably short traceroute to TCP port 80 - http web traffic:
[tt]# traceroute -q 1 -N 1 -T -p 80 imgbox.com
traceroute to imgbox.com (72.251.194.218), 30 hops max, 52 byte packets
1  192.168.0.1 (192.168.0.1)  2.795 ms
2  lo0-central10.ptw-ag03.plus.net (195.166.128.197)  22.253 ms
3  link-a-central10.ptw-gw01.plus.net (212.159.2.152)  21.835 ms
4  xe-4-3-0.ptw-cr01.plus.net (212.159.0.244)  22.612 ms
5  te9-4.ptn-gw01.plus.net (195.166.129.33)  20.971 ms
6  ae1.pcl-cr02.plus.net (195.166.129.3)  22.093 ms
7  72.251.194.218 (72.251.194.218)  21.693 ms[/tt]
A longer route to tcp port 443 (https)
[tt]# traceroute -q 1 -N 1 -T -p 443 imgbox.com
1  192.168.0.1 (192.168.0.1)  1.478 ms
2  lo0-central10.ptw-ag03.plus.net (195.166.128.197)  21.997 ms
3  link-a-central10.ptw-gw01.plus.net (212.159.2.152)  21.312 ms
4  xe-4-3-0.ptw-cr01.plus.net (212.159.0.244)  26.093 ms
5  ae2.ptw-cr02.plus.net (195.166.129.5)  21.520 ms
6  ae1.pcl-cr02.plus.net (195.166.129.3)  48.049 ms
7  te2-1.gr9.plus.net (212.159.2.110)  20.893 ms
8  tun0.pcl-gw01.plus.net (212.159.2.105)  21.223 ms
9  flowers2.servers.plus.net.uk (212.159.2.98)  21.483 ms
10  core1-Te0-0-0-0.ealing.ukcore.bt.net (213.121.193.20)  24.564 ms
11  transit1-pos2-1.ealing.ukcore.bt.net (194.72.9.2)  21.894 ms
12  ae-71-71.csw2.Paris1.Level3.net (4.69.161.82)  28.436 ms
13  4.69.168.71 (4.69.168.71)  27.620 ms
14  t2c2-p3-0-1.uk-lon1.eu.bt.net (166.49.208.110)  22.868 ms
15  t2c4-xe-0-3-1-0.uk-lon1.eu.bt.net (166.49.237.244)  23.068 ms
16  border3.po1-20g-bbnet1.nym008.pnap.net (216.52.95.4)  97.096 ms
17  t2c3-xe-1-3-1-1.nl-ams2.eu.bt.net (166.49.237.210)  41.828 ms
18  0.ae57.csr2.lga6.us.voxel.net (208.122.44.210)  98.398 ms
19  0.te1-2.tsr2.ams2.nl.voxel.net (173.231.161.118)  29.052 ms
20  0.te4-3.tsr1.lga3.us.voxel.net (208.122.44.93)  111.438 ms
21  0.ae59.tsr1.lga5.us.voxel.net (208.122.44.202)  98.698 ms
22  0.ae57.csr2.lga6.us.voxel.net (208.122.44.210)  99.393 ms
23  72.251.194.218 (72.251.194.218)  100.262 ms[/tt]
pwatson
This site confirms that imgbox has been list by the IWF
http://iwfchecker.lightning-bolt.net/?site=imgbox.com
bobpullen
Fixes: 316
I've asked for it to be addressed as part of this problem.
bobpullen
Fixes: 316
Should be sorted now.
