Intel Security Flaw
- Re: Hope this dont slow down my i7 :(
04-01-2018 11:29 AM
Phoronix has done some analysis on the performance impact
https://www.phoronix.com/scan.php?page=article&item=linux-more-x86pti&num=1
04-01-2018 2:32 PM
Why are these people whining about a "CPU bug"?
This is just a fault in the way the kernel can be implemented.
It's not fixable by changing the chip or its firmware.
04-01-2018 3:56 PM - edited 04-01-2018 4:20 PM
meltdown patch I think http://www.catalog.update.microsoft.com/Search.aspx?q=KB4056892
Edit: After applying that then re-checking with the tool above it says I'm still Vulnerable. Hmmm etc...
04-01-2018 4:30 PM - edited 04-01-2018 4:30 PM
i just check my CPU and am OK
Tool Started 04/01/2018 16:28:38
Manufacturer: ASUS
Model: All Series
Processor Name: Intel(R) Core(TM) i5-4690K CPU @ 3.50GHz
OS Version: Microsoft Windows 10 Pro Insider Preview
Engine: Intel(R) Management Engine
Version: 9.1.25.1005
SVN: 1
Status: This system is not vulnerable.
Tool Stopped
04-01-2018 4:44 PM
meh.....
Tool Started 04/01/2018 16:42:41
Name:
Manufacturer: HP
Model: HP Spectre x360 Convertible
Processor Name: Intel(R) Core(TM) i7-6500U CPU @ 2.50GHz
OS Version: Microsoft Windows 10 Home
Status: This system is vulnerable.
Tool Stopped
04-01-2018 4:45 PM
Oh you have the Insider preview you little tinker!
04-01-2018 5:07 PM
Has anyone got the new update/fix yet ?
04-01-2018 5:12 PM - edited 04-01-2018 5:12 PM
I have the 'MELTDOWN' update above come in on my desktop pc, but I've had to apply the above patch update manually to my laptop pc.
KB4056892
04-01-2018 5:14 PM - edited 04-01-2018 5:14 PM
I have that patch too just got it, and my system still shows vulnerable.
04-01-2018 5:27 PM
So just waiting for the 'Spectre' patch now!
04-01-2018 5:46 PM
@St3 a lot laughed when i started windows insider ,, But looks like its the way to go
04-01-2018 6:14 PM
This is a pretty good read on the subject https://www.theregister.co.uk/2018/01/04/intel_meltdown_spectre_bugs_the_registers_annotations/
04-01-2018 8:30 PM
I asked this earlier, but got no reply - anyone know? " I know there's no detail about this threat, but I wonder how close to your machine an attacker will have to get, or how they would?"
04-01-2018 9:55 PM
Don't expect a patch for spectre. It's a hardware flaw. To properly fix it, it's a new CPU.
05-01-2018 12:19 AM
@St3 I was under the assumption that you had followed the link from the tool to update the intel management engine....
follow the links at the bottom of the page to your MB or Manufacturer and update the management engine to the latest version.
Linky to info.... https://www.intel.com/content/www/us/en/support/articles/000025619/software.html
