Bipac 8800NL with "Plusnet Fibre" (no phone line)
- My Router
- Re: Bipac 8800NL with "Plusnet Fibre" (no phone li...
3 weeks ago
Hi, we've been Plusnet customers for years and have always used a trusty Bipac 8800NL (v1 I think) router. We don't use this for wireless, just the WAN connection, and it's rock solid. We're on Unlimited Fibre Extra at the moment
We can save a little money by switching to the Plusnet Fibre package, which is without a phone line. When I go to switch products in the portal it strongly suggests we should take a "Hub Two" router for the connection. I'd much rather just stick with what we have. I've looked at the router requrements and it say that if our router supports VDSL2 (which it does) it should work OK?
The projected broadband speeds for the new package are the same as we have currently. I'm assuming the technology is the same as our current package and I won't need to reconfigure anything if/when we switch?
Thanks!
Re: Bipac 8800NL with "Plusnet Fibre" (no phone line)
3 weeks ago - last edited 3 weeks ago
@bencook you are correct, the technology is exactly the same, no reconfiguration required.
Having said that, I'd be inclined to take the offer of the Hub 2 for the p&p charge of £6.99. Its useful to be able to swap to it if you have an issue and PN need to investigate and as a spare in case your 8800NL develops a fault.
3 weeks ago
- My Router
