slow internet speed
captainmike
slow internet speed
I've just moved to PlusNet and just over a day into my activation. my estimated download speed should be  42-60 mbps
however I'm only getting around 10 mbps and have been since the start, so not sure why or when it'll start picking up, any help?
Tags (1)
11 REPLIES 11
Legend
Fixes: 260
Re: slow internet speed
@captainmike
BTW Performance Tester - Over a wired (Ethernet) connection if at all possible, please report the 'ADDITIONAL DIAGNOSTICS'. This test is recommended to be performed with only one device connected.
For the Hub One -
For the Hub Two -
captainmike
this should be the info you required
captainmike
Desktop Screenshot 2024.04.17 - 20.05.15.24.pngDesktop Screenshot 2024.04.17 - 20.06.28.53.pngDesktop Screenshot 2024.04.17 - 20.20.56.40.png
Legend
Fixes: 260
Thanks for that. One thing shouts out to me - your D/S SNR margin is hellishly high. Before I make any further suggestions, which master socket do you have, and is your Hub plugged into directly?
captainmike
this is the master socket not using the micro filter. i should note that i had an engineer come visit as i was having similar issues with my previous provider. The engineer came round and had to move my mate socket someplace else , so he had to re wire it, but once he was done then my internet went back to what it should of been, but now that i switched its back to how it was before it was fixed.mastersocket.jpg
Legend
Fixes: 260
OK, so the Hub is plugged directly into the left socket? If so, I suggest you report a fault via: https://www.plus.net/help/report-a-problem/
Let us know the response, please/
captainmike
ok will do that first thing tomorrow , does it need to be a text or can i phone them?
Legend
Fixes: 260
Do it as a text - it initiates a set of tests automatically.
captainmike
ok ive tried texting it , but its saying unable to auto match this mobile  with a broadband account, please provide a full phone number including area code....
but this is the phone that was used to create my account and all. i dont have a landline nor do i know the number
Legend
Fixes: 260
@captainmike Sorry, I forgot that Plusnet have failed to recognise that SoGEA provisions don't have a 'phone number' allocated, and have not made provision for this situation. You will have phone them and do it the hard way.
captainmike
haha thought so, ok will call during open hors , and will let you know on results cheers
