"I have to follow the protocol" - which is code for "Pi??off !"
- Re: "I have to follow the protocol" - which is co...
a month ago
Hi - I having problems with customer services regarding line dropouts and speed problems.
I have rung customer services a few times and the response is the same.
Me - I have a problem with my line - I have previously run the Plusnet tests and waited 24 hours
Handler - " Oh I can see from your notes the test results "
Handler - " I have to follow the protocol and re-run the tests"
Handler - " I see that you are not getting your contractual speed -- you are getting only 15Mbps"
Handler - "I'll make a record of your issue"
Handler - " Wait for 24 hours and get back to us - the protocol does not allow me to raise this problem to the next level" -- which is code for - We hope that magic internet fairy will solve the problem.
Me ( After 24 Hours ) I have a problem with my line - I have previously run the Plusnet tests and waited 24 hours
Handler - " I see that you are not getting your contractual speed"
Handler - " Please wait for 24 hours and get back to us - the protocol does not allow me to raise this problem to the next level "
Repeat 24 Hours later !!!!
Re: "I have to follow the protocol" - which is code for "Pi??off !"
a month ago
BTW Performance Tester - Over a wired (Ethernet) connection if at all possible, please report the 'ADDITIONAL DIAGNOSTICS'. This test is recommended to be performed with only one device connected.
For the Hub One -
For the Hub Two -
a month ago
Hi Jab1 - You have not read my post.
The facts are -
1) I have run the Plusnet tests
2) There is a known issue with my line/speed - running more tests will not fix the fault.
but I still have to wait another 24 hours before the protocol allows the issue to be escalated
Please read the post before posting a template reply
a month ago
@DrWho I DID read your post, I am merely offering help which does not follow the script-readers 'protocol', but if you don't want that help, just say so - your choice.
4 weeks ago
Thank you - However, Plusnet has agreed there is an issue.
I am frustrated with the "wait 24 hours protocol " - hoping the issue will somehow fix itself.
'Insanity is doing the same thing (running the same tests) over and over again and expecting different results. '
4 weeks ago
I understand your frustration - if I was still a PN customer and got that response continually, I would blow my top, big time.
However, IF you supply what I have asked for, there may be a way to break this apparent deadlock. Unfortunately, Community members don't have access to the PN systems, so we need you to supply us with some details we can form an opinion from, and hopefully suggest a way forward - as I say, we are not bound by this claimed 'protocol'.
4 weeks ago
4 weeks ago
That is why a 'push' from someone NOT reading off a script can sometimes be useful.
4 weeks ago
I've brought this to the attention of forum staff. Lets see if we can get a sensible response...
4 weeks ago
Thanks, @MisterW
4 weeks ago - last edited 4 weeks ago
4 weeks ago
No - my problem is not solved.
Me ( after giving my account details ) what is going on ?
Handler - Can I read your notes?
Handler - Nothing has changed - we will have more information on Monday (22nd)
Handler - Ring back on Monday - nothing I can do.
Me - Can I speak to a manager?
Handler - no
Me - I want to speak to a manager
Handler - ( after a lot of pressure ) puts me on hold for 5 mins
Handler - Sorry no managers are available - a manager will ring you back.
Me - When ? in the next hour? - today ?
Handler - I don't know ...Err Yes within the next hour ( which is code get off my back and go away )
Who wants to take a bet that no manager will ring me? 🙂
My next call will be to the retention team - bye-bye to plusnet after 10 years
4 weeks ago
All of you should have taken the bet .
Shock Horror - a team leader ( with a ton of softsoap ) has rung me
Guess what - He is very sorry but can't do anything - "PN will ring you on Monday (22) and inform you of any updates."
So now - it is wait 48 hours 🙂
I can hear the can being kicked down the street.
It looks like Virgin ( We have the cable already) here I come - twice the speed for the same price
4 weeks ago
Did he advise whether the problem has been raised to either the triage team or Openreach ?
4 weeks ago
Is there an open ticket on your account? See the PN Ticket button below.
If the issue has been raised with BT Openreach then the 22nd it is as THEY will not entertain a chase from an ISP until their next review date / time.
If the issue has not been raised to Openreach then Plusnet should have advised what action is being taken, by whom and when. At the very least, this should go to the triage team.
