mybroadbandspeed test
artmo
Aspiring Champion
Re: mybroadbandspeed test
Seems to be something wrong with 'My Broadband Speed Test'  Worked on the second attempt then on a third try got an error message 'not accessible Huh
Strat
Fixes: 565
It's a pity this 'Mybroadbandspeed' problem as I've used it for quite some time and it's always delivered.
artmo
Aspiring Champion
It seems to be OK again now so maybe there was a glitch that got fixed.  Maybe a man and his screwdriver arrived at PN Towers Grin Grin
Strat
Fixes: 565
Still fails for me in Opera but works OK in FF Undecided
MrC
It looks like either the webserver running the site is repeatedly dying (telnet to port 80 occasionally gives connection refused - ie nobody home) or there's more than one server hiding behind the one ip address and one or more of them are defunct in some way or other.
Anywaysup it's broken Smiley
colintivy
Hi folks!
Contrary to the later posts all has been well here, 21.17 last night and 11.04 just now. Hope this maintains its performance for and gets better for all you others still suffering. Will keep an eye on the situation and will report as necessary.
Regards,
colintivy  Smiley
Strat
Fixes: 565
Which browser are you using Colin?
colintivy
Hi Strat,
FireFox 3.5 at the moment, sorry i thought that I had declared this earlier. It has not been a problem in general.
Last check 10.19 this morning , still OK,
colintivy  Smiley
artmo
Aspiring Champion
Yep, everything seems to be back to normal again.  Smiley
James
Good stuff.  Thanks for the update Smiley
Strat
Fixes: 565
Quote from: colintivy
Hi Strat,
Yes you did sorry Embarrassed
Just checked in Opera and it worked. Smiley
colintivy
Hi folks,
Just rechecked....15.18.... all OK !!!
colintivy  Smiley  Smiley
nolluwhereilive
...working fine now on IE8...?
colintivy
Still working OK @ 16.14 26th Aug. Noted that Graph date headings now leave out the month. My download speed gone up to nearly 3Megs, quite unheard of ever here !!!
colintivy Smiley Smiley Smiley
Fixes: 416
I would like to complain that the pointer on the speed test wont go round far enough. On my office connection it just gets to the 10mb+ mark and sticks there!!  Grin ( ducks to avoid all the rotten eggs from those with 'normal' ADSL lines )
Actually for a while after we were upgraded to ADSL2, it still only gave about 6mb speeds and I put it down to a fault with the speedtester. Then we realised we still had a 10mb network card as the uplink from our firewall to the ADSL router, doh! Roll_eyes Replacing with a 100mb card gives a nice 14-15mb speed ( ducks again ) Smiley
