Autoturn Problem
- Autoturn Problem
Autoturn Problem
08-08-2009 3:00 PM
Has anybody had problems with the autoturn server again?
I issue the finger postmaster@autoturn.plus.net command and I just get "Connection Refused"
It used to work.
Some crazy mad Farm worker took a great chunk out of one of our telegraph poles with a hedge trimmer and took the phone line with it.
ADSL been down 3 days. When I went to De-queue I just got the connection refused error.
I'm not using the Plusnet firewall and I'm issuing the command on the Server itself, still no joy.
Using Netgear DG834G version 4 in standard config (apart from the SMTP firewall hole)
Any ideas. I think there is still mail to dequeue.
Andrew
Re: Autoturn Problem
08-08-2009 3:08 PM
08-08-2009 11:00 PM
09-08-2009 9:29 AM
09-08-2009 5:31 PM
finger postmaster@autoturn01.plus.net
which failed with a DNS issue
So they then told me:
Quote Can you please confirm that you are issuing the finger command from xxx.xxx.xx.x?
If the problem persists. please let us know and we will dequeue any emails to xxx1xx.xx.xx for you
Bur of course I want to be able to use autoturn and said this and they replied:
Quote I can confirm that our autoturn mail servers are up and runnning smoothly. I've just updated the details of your domain. please allow upto 24 hours for these changes to take place
But I certainly can't talk to them, and you can't so I dont think its me, or you, it is PN - but apparently not according to the person in Customer Services. So I've asked them what they have changed at their end to break things
I remember when Customer Support was good...
09-08-2009 6:38 PM
09-08-2009 8:59 PM
I haven't received any email via autoturn since 5 August.
99.9% of email that comes this way is SPAM anyway but there is the odd one that is not.
I'll raise a ticket also tomorrow if the situation doesn't change.
Andy
09-08-2009 9:09 PM
[tt]steve@kodaly:/tmp$ finger postmaster@autoturn.plus.net
[autoturn.plus.net]
212.159.61.36
Your IP address is 212.159.61.36
1 messages queued
Email delivery triggered to 212.159.61.36
steve@kodaly:/tmp$ traceroute www.wordpress.org
traceroute to www.wordpress.org (72.233.56.139), 30 hops max, 40 byte packets
1 192.168.0.66 (192.168.0.66) 26.197 ms 25.625 ms 25.071 ms
2 lo0-plusnet.pcl-ag03.plus.net (195.166.128.109) 41.089 ms 42.025 ms 43.484 ms
3 gi1-6-703.pcl-gw01.plus.net (84.92.0.181) 45.184 ms 46.358 ms 47.833 ms
4 xe-1-2-0-0.lon20.ip4.tinet.net (213.200.79.233) 50.025 ms 51.957 ms 53.407 ms
5 xe-2-0-0.nyc30.ip4.tinet.net (89.149.187.70) 125.374 ms 127.283 ms xe-0-0-0.nyc30.ip4.tinet.net (89.149.187.62) 128.727 ms
6 Te-3-4.car3.NewYork1.Level3.net (4.68.110.77) 132.159 ms 109.315 ms 111.527 ms
7 vlan79.csw2.NewYork1.Level3.net (4.68.16.126) 107.076 ms 105.726 ms 121.616 ms
8 ae-74-74.ebr4.NewYork1.Level3.net (4.69.134.117) 127.062 ms 131.149 ms 131.443 ms
9 ae-3.ebr2.Dallas1.Level3.net (4.69.137.121) 168.076 ms 170.061 ms 171.136 ms
10 * * *
11 DATABANK-HO.edge3.Dallas1.Level3.net (4.71.170.6) 180.820 ms 180.959 ms 182.117 ms
12 66.18.0.142.databank.com (66.18.0.142) 178.184 ms 141.393 ms 143.218 ms
13 * * *
14 wordpress.org (72.233.56.139) 151.287 ms 153.167 ms 154.570 ms
[autoturn.plus.net]
finger: connect: Connection refused
steve@kodaly:/tmp$
[/tt]
Ingore the traceroute, that was me checking something.
So a work and then a fail.
CS deny there are any problems with it at all.
Hopefully maybe tomorrow someone like Bob can have a shufty?
09-08-2009 9:22 PM
Quote from: SteveA Hopefully maybe tomorrow someone like Bob can have a shufty?
Looks to me like it's not accepting connections at the moment:
C:\Users\Bobby>telnet autoturn.plus.net.uk 25
Connecting To autoturn.plus.net.uk...Could not open connection to the host, on p
ort 25: Connect failed
Without knowing any of the details, I'd warrant a guess that the servers are under extremely high load. It's been a problem on and off for a while now and I know we've been looking at potential ways to fix it. A problem with the mail queues was also raised on Saturday that I think had something to do with the autoturn boxes (ref: 57724).
I'll get somebody to take a look into things tomorrow morning if the situation remains unchanged...
09-08-2009 10:08 PM
If they are overloaded and are just refusing connections then why did CS say :
If CS had simply come back and told me that they're over loaded then I'd have said fine. but CS didn't. Please look at the ticket I opened.
09-08-2009 10:13 PM
10-08-2009 11:07 AM
root@kodaly:/tmp# finger postmaster@autoturn.plus.net
[autoturn.plus.net]
212.159.61.36
root@kodaly:/tmp#
[autoturn.plus.net]
root@kodaly:/tmp#
10-08-2009 1:33 PM
Simular problem after my SMTP rolled over. Server back up but autoturn is alternating between Connection Refused and Connection Timed Out
I'll get support to manually dequeue.
10-08-2009 1:36 PM
Quote from: SteveA Its still flaky. Here are two fingers done about 2 hours apart, I wanted to sync email before shutting down the computer so I can clean the fluff out of its fans
[autoturn.plus.net]
212.159.61.36
root@kodaly:/tmp#
[autoturn.plus.net]
root@kodaly:/tmp#
You access the internet with your root account?
10-08-2009 1:37 PM
620 mails... dont think I really wanted to dequeue now
