Wrong line profile
Fixes: 411
Re: Wrong line profile
Bridge taps are unterminated extensions of the telephone line or loop. They can alter the impedance of the local loop, especially at ADSL & vDSL frequencies. With DC (AC when the phone rings!) voltage the bridge tap behaves like an open circuit (so no effect), but with high frequencies (ADSL & vDSL), the loop becomes a transmission line "stub". This impedance mismatch can cause a wide variety of problems, but typically it causes a reflection of data bits from the tap-point back to the point of transmission. This results in bit errors, or in English, your speed will most probably reduce.
A bridge tap can affect the speed at the test socket if the wiring is not correct. If wired correctly, Extensions SHOULD be disconnected when the test socket is being used.
Wonder if a bridge tap can be caused before the test socket, where it was repaired in the driveway after being severed 4 years ago.
Assuming the repair was done by Openreach then it shouldn't...
alicelight80
Thanks, line in driveway was repaired same day, I think by Openreach (Wales & West dealt with it all as they caused it).
Fixes: 420
@alicelight80
Whilst my money would be you being provisioned, or you are stuck due to a software glitch, on the 40/10 service, another question: Are you on a static IP address?
alicelight80
No I don't think I'm on a static IP, I had one a few years ago (can't remember if it was this house, think not) and have gone through several different suppliers since then and not set one up. IP online check says 'likely dynamic'
MatthewWheeler
Fixes: 480
Hi @alicelight80
I can see you spoke with a colleague today who's raised a request to reset your DLM profile
Have you noticed any difference?
 Matthew Wheeler
alicelight80
Thanks, no difference at all I'm afraid, I think he said he would call me back before he leaves this afternoon with next steps.
@MatthewWheeler  given that the DLM reset didn't restore @alicelight80 's speeds,
can you check that  @alicelight80  has been provisioned on 80/20 SoGEA. and not 40/10 ?
as it looks unusual that their router download "Data Rate:" is exactly at 40Mbps,
given that the corresponding "Maximum Data Rate:" is quite a bit higher !
alicelight80
Hmm, well I think my tech finished his shift at 4.30pm and no promised call back received .
Should I text ADVISOR again and run the risk of getting someone who wants to start from the beginning and film my test socket?
Many thanks
Legend
Fixes: 260
@alicelight80 I wouldn't start the process again - Plusnet are aware and should be monitoring what is happening - but note the 'should'.
@MatthewWheeler  You still around to investigate, please?
alicelight80
Just noticed router dropped connection and re-connected higher, particularly upload, though download still below the handback threshold of 57mpbs on this 80 line - wonder if it'll improve or regress... (previously was stable at max 35 down, 7.5 up, data rate profile was 40 down, now 50)
alicelight80
Oh the noise margin has changed too
Legend
Fixes: 260
That is looking much better, @alicelight80 . Noise margin back where it should be - roughly - and speeds creeping up, although you might get a couple more 'blips' as your speed (hopefully) gets above the H/B threshold.
Do you still have an engineer planned to check the bridgetap issue?
alicelight80
No engineer planned as nobody got back in touch today following the reset - I can see DLM is trying to do its thing. I guess I'll wait a few days and chase if my download is much less than 57mbps, though maybe negligible in real life use.
Really pleased with the upload speed so far anyway; we both work from home on local government VPN including lots of file uploads / downloads, including AutoCAD, so I think husband in particular will notice a difference in sending large files.
Legend
Fixes: 260
OK. The bridge tap does need investigating though, as until it is rectified you may find things regressing again. See how things go tomorrow, and if you don't get an engineer visit offered, come back and lets see if we can get one arranged.
alicelight80
Ok will do, that makes sense, thanks for your help
