What is the master socket
- What is the master socket
- « Previous
- 1
- 2
- Next »
Re: What is the master socket
29-12-2011 6:37 AM
this is the Kitz bit
Message 16 of 24
(446 Views)
29-12-2011 7:14 AM
Quote from: rongtw but from what i read on the forum is that 90% of problems are due to this socket
No, 90% of problems are due to the internal telephone extension wiring. If this has been done correctly (which is by no means always the case) then the extensions are wired to the removable part of the faceplate and removing the faceplate cuts off all the telephone extension sockets.
Quote from: rongtw ,, i must admit that my own has never been connected in the original socket , and is perminantly in the test socket , so bascially i have a half open socket .
If you can take the bit you removed and throw it across the room then it was unnecessary to remove it and you might as well put it back. If you cannot throw it across the room because it is attached to some wires then removing it served a purpose but it is likely that somewhere in your dwelling there is at least one telephone extension socket that doesn't work any more.
Quote from: rongtw the point is ,, Why dont BT fit a socket where removing half of it becomes unneccssary ???.
These days they do - but only in a new build or when they have reason to replace the old master socket. BT also supplies its broadband clients with something called a "broadband accelerator" (formerly "iPlate") http://www.productsandservices.bt.com/consumerProducts/displayTopic.do?topicId=25075&s_cid=btb_FURL_... which should overcome most problems caused by bad internal telephone wiring. So the good question is: why don't Plusnet supply the "Broadband Accelerator"?
Message 17 of 24
(446 Views)
29-12-2011 8:46 AM
ReedRichards , i have no wires attached to my faceplate all i have is , BB modem & a phone connected to the filter into the test socket , as requsted to do by PN .so in my case this is not doing me any better than pluging direct in the faceplate ?
the reason i stated 90% was that everyone is automatically asked to connect to the test socket , if they have any problems , which in some setups does not help ,,, when in fact it is only there to remove any internal wireing from the test socket am i correct ?
so surely before PN ask you to connect to the test socket they should ask if you have any extension lines into your socket ?
PS BT broadband excelerator is expensive £90 to gain 0.5 mg speed boost
Message 18 of 24
(446 Views)
29-12-2011 9:18 AM
Quote from: rongtw ReedRichards , i have no wires attached to my faceplate all i have is , BB modem & a phone connected to the filter into the test socket , as requsted to do by PN .so in my case this is not doing me any better than pluging direct in the faceplate ?
No, in your case you can replace the faceplate.
Quote from: rongtw PS BT broadband excelerator is expensive £90 to gain 0.5 mg speed boost
I don't know where you do your shopping. The BT "Broadband Accelerator" is supplied at a nominal handling charge to BT Broadband customers. It costs £8.89 here http://www.shop.bt.com/products/bt-iplate---bt-broadband-accelerator-58LT.html and I presume the bt.com address means this is a genuine BT shop.
Message 19 of 24
(446 Views)
29-12-2011 10:29 AM
It isn't just the internal wiring that gets disconnected, it is the faceplate too - which has also been known as a source of faults.
The demarcation point is the test socket - and if faults exist with that alone, then everyone can be sure they have done sufficient tracing, after router & cable checks, to *know* the problem lies on the BT side.
That is the problem I have with the external NTE - that it makes it impossible for the customer to test back to the demarcation point, or disconnect internal wiring. That guarantees the need for a BT engineer, and greatly increases the chances of being charged.
Plusnet Customer
Using FTTC since 2011. Currently on 80/20 Unlimited Fibre Extra.
Message 20 of 24
(446 Views)
29-12-2011 10:33 AM
You are now talking about two different things !
'ReedRichards' is talking about a filtered faceplate that replaces a standard master socket.
'rongtw' is talking about the service that BT offered a couple of years ago where a BT engineer visits and optimizes customers equipment.
http://crave.cnet.co.uk/accessories/bt-broadband-accelerator-half-a-meg-faster-or-your-cash-back-492...
Quote BT sells broadband to millions of people in the UK and realises it can all be rather difficult, especially if you're over 50 and think a router is a special kind of pig. Happily, it offers a bunch of home IT support services to keep you consuming the Internets, the latest of which is the Broadband Accelerator. Simply put, you pay £90 for an engineer to come and make your Web go faster and if he fails to improve it by half a meg (0.5Mbps), you get your money back.
Message 21 of 24
(446 Views)
29-12-2011 10:36 AM
Quote from: purleigh 'ReedRichards' is talking about a filtered faceplate that replaces a standard master socket.
[pedant] BT I-Plate actually [/pedant]
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
Message 22 of 24
(446 Views)
29-12-2011 3:04 PM
Quote from: 4C [pedant] BT I-Plate actually [/pedant]
[Oneupman] No, BT rebranded their "I-Plate" as a "Broadband Accelerator".[/oneupman]
Message 23 of 24
(446 Views)
29-12-2011 4:54 PM
Quote from: ReedRichards [Oneupman] No, BT rebranded their "I-Plate" as a "Broadband Accelerator".[/oneupman]
Why was that were Apple suing them
To do is to be - Neitzsche
To be is to do - Kant
do be do be do - Sinatra
Message 24 of 24
(446 Views)
- « Previous
- 1
- 2
- Next »
