Weird Issue Speed drops to 2mb for SSL connection
- Weird Issue Speed drops to 2mb for SSL connection
22-08-2011 5:09 PM
Hi ,
I seem to have Run in to a small issue.
Me and A few cousins run a Ftp server hosted in the Netherlands , which we use to backup our documents , personal files, photos , linux iso etc. (Nothing iIlegal)
Now i have just moved from the Unlimited speeds 60gb account on to the Unlimited Broadband account and for some reason my speeds have droped down to 2mb sec for downloading of my server , i have speed tested from other wesbites including the Server hosters speed test link and i max my connectiion speed of at 16mbs. My server is ssl and after further testing i have pin pointed that my speed slows down to 2mbs for any ssl connection :S When i was on the 60gb a/c the same would happen but when i added the pro addon for £5 i was totally fine and this Unlimted account has no option for the Pro addon. I dont want to leave Plusnet because to be honest with you i love plusnet , the support , the prices , service etc
My apologies for the rambling
Many thanks
Message 1 of 6
(915 Views)
5 REPLIES 5
Re: Weird Issue Speed drops to 2mb for SSL connection
22-08-2011 5:15 PM
http://usergroup.plus.net/prodcomp1.php may give the answer
Message 2 of 6
(507 Views)
22-08-2011 5:20 PM
Hi RogerMcnulty,
As per the expected download speeds table for the Unlimited product here:
http://www.plus.net/support/broadband/products/archive/plusnet_unlimited_archive.shtml#downloadSpeed...
Download servers are rate limited to 2Mbps at all times. Unfortunately as you know there is no option for the Pro Add-on on the Unlimited product. This means that you would have to switch to Plusnet Extra to avoid the 24/7 rate limiting.
Message 3 of 6
(507 Views)
22-08-2011 5:24 PM
The limit is only afternoon and evening - midnight to noon is unlimited so you would need to schedule your downloads if at all possible
Message 4 of 6
(507 Views)
22-08-2011 8:01 PM
Which at your line speed you should be able to pull well over 8gb/night just in the unlimited hours.
There is no need to worry about 'talking' about 'illegal' doings, as the forum rules states - talking about them is fine encouraging law breaking etc. is bad however
unless your getting nightly builds, or are downloading every edition of ever distro .. thats lots of linux
Regards
Regards
Message 5 of 6
(507 Views)
23-08-2011 10:50 AM
Quote from: Oldjim The limit is only afternoon and evening - midnight to noon is unlimited so you would need to schedule your downloads if at all possible
My mistake. Oldjim is correct. On the Unlimited product the rate limiting occurs between 12pm and 12am for download servers.
Message 6 of 6
(507 Views)
