Was I lied to?
- Re: Was I lied to?
- « Previous
- 1
- 2
- Next »
Re: Was I lied to?
22-02-2014 1:25 PM
QoS applies per line and across the network as a whole. We scale to make sure that Bronze traffic (P2P, Usenet) should be running at line speed. This means the QoS at a network level should take effect if we've messed up with our forecasting, or if there is a platform failure, or major event. At a line level, it should work to make sure that when you fire up your usenet downloads, your VoIP/Gaming etc works fine.
Kelly Dorset
Ex-Broadband Service Manager
Message 16 of 17
(128 Views)
Re: Was I lied to?
22-02-2014 1:31 PM
Thanks again… and you get my vote to edit the traffic management info page
Message 17 of 17
(128 Views)
- « Previous
- 1
- 2
- Next »
