Was I lied to?
- Was I lied to?
Was I lied to?
21-02-2014 4:15 PM
I can’t find anything on here mentioning unlimited bb has no traffic management and when I login to the member centre the pro add-on is an option. Also, I found the following live page:
http://www.plus.net/support/broadband/speed_guide/traffic_management.shtml
As you can see it says my unlimited (standard) broadband will indeed have traffic management.
Was I lied to or is this out of date information?
Re: Was I lied to?
21-02-2014 4:26 PM
Re: Was I lied to?
21-02-2014 4:36 PM
As pwatson has stated we do have traffic prioritisation, however, this is designed in a way to ensure that you experience Unlimited broadband in the best way. As you are a a newer broadband package you wouldn't actually notice any benefit from the Pro Add-on service. Of course it's your choice if you wish to have this anyways at the cost of £5 per month.
Hope the article that pwatson included in their reply has helped clarify things for you.
Re: Was I lied to?
22-02-2014 12:21 AM
I’m also none the wiser as to why the pro add-on is available to me if I wouldn’t notice any difference. If you look at this link I posted above it suggests it improves the priority of VPN, External FTP, Download sites, Peer to peer/Usenet and other traffic. Is this not the case?
Re: Was I lied to?
22-02-2014 12:42 AM
Re: Was I lied to?
22-02-2014 2:41 AM
I had read up on the traffic management Plusnet use and was prepared to get the pro add-on at a later stage if necessary. I had called sales because you now can’t add call divert when placing a new order online and when I asked if I could add or remove the Pro option at a later stage without affecting the contract I was given this new info about there being no traffic management. I thought this was great, but I’m now being told there is management in place and worse still, the pro add-on will make no difference.
I will be delighted if downloads are not affected. I only get about 3Mbps so I prefer to download rather than stream content. Coming from an o2 (now Sky unfortunately) connection that had no traffic management I hope you can understand my concern. It’s fair enough trying it first, but will I have time to cancel after waiting for activation then the 10 day training phase if it’s not going to work out?
Re: Was I lied to?
22-02-2014 2:59 AM
Re: Was I lied to?
22-02-2014 7:49 AM
Quote from: fester Unless I have misunderstood things, if I was to use a download server or peer to peer app I would have less priority (and speed depending on network load) than my neighbour who is gaming or streaming video.
The prioritisation works on your line so that if you're downloading something and then choose to watch iPlayer (for instance) then the video stream get priority. What others are doing should have no affect (under normal circumstances)
If you're not streaming you should see downloads running at line speed.
Re: Was I lied to?
22-02-2014 9:30 AM
Re: Was I lied to?
22-02-2014 10:13 AM
“As customer numbers and usage grows, we have to increase the capacity of our network to make sure there's enough bandwidth for everyone. When the network is busy, it's easy for things to get out of control. Peer-to-peer, video streaming and large file downloads can flood the network quickly and use up the bandwidth. If this happens, it reduces the speed of web browsing, email, gaming and other types of web traffic. Traffic management prevents this from happening.”
If that info is wrong and it’s purely an individual/personal management that doesn’t relate to network load then it’s great. Although I would prefer to manage the download/web browsing ratio myself than give control over to automated system.
Fingers crossed
Re: Was I lied to?
22-02-2014 10:20 AM
This is why the system is designed to prioritise these over non time sensitive protocols.
Or would you rather have your time sensitive traffic seriously affected under these circumstances. I certainly wouldn't
Re: Was I lied to?
22-02-2014 10:52 AM
Re: Was I lied to?
22-02-2014 11:35 AM
@pwatson, thanks again for the info If you expand the traffic prioritisation table on the page I linked it goes on to state:
“What this means: at busy times, higher priority queues will take bandwidth from the lowest queue(s) currently in use (but never enough to take the lower queue below its minimum bandwidth allowance).”
As you can see it then goes on to list various products including Unlimited and what priorities are allocated and the change that the pro add-on gives. If the pro add-on would make no difference why does the info on the page tell me it does? In contrast, if it does have an effect and it’s only an internal rather than network prioritisation why would someone pay £5 per month to prioritise traffic within a household in this way?
Am I going mad or do they need to revise the info on this page?
Re: Was I lied to?
22-02-2014 12:36 PM
Ex-Broadband Service Manager
Re: Was I lied to?
22-02-2014 1:16 PM
Queues as in internal application traffic up to the max speed of the line and only on a network level if there is a problem?
