Unable to connect to specific web-site
Jodel
Folks, I have been unable to log on to the web-site for ‘Woosh’ bicycles:
https://wooshbikes.co.uk/
I get a message advising that you have exceeded the maximum number of requests today. Please come back later.’ This has been the case for several days.
I have checked with the web-site owner and there is no problem as far as they are aware. I checked my IP address with 'Akemai' and 'whatismyipaddress' and it is not shown as blacklisted anywhere.
I can access the Woosh web-site with my mobile phone using the 4g network, but not if the phone is connecting via my own WiFi.
All other web-sites I try are working OK, I just can’t get past the error message on the Woosh site.
I would be grateful if anyone could advise on how I should proceed or suggest a possible resolution.
25 REPLIES 25
Fixes: 162
Re: Unable to connect to specific web-site
Most odd - I can connect to it
However not everyone’s connectivity is the same. I have a static IP address so I’m on the high touch network which means I go through Plusnet’s data centres before touting to the internet.
Dynamic IP address users (most people) route differently. Also using parental safeguards (different DNS servers) also impact connecting characteristics.
Are you using the Plusnet router? Have you changed the DNS settings?
corringham
Seasoned Champion
Fixes: 16
Have you tried connecting using a different browser?
Alternatively, try clearing the cookies for that site.
Jodel
Thanks for the comments folks.
I've tried three different PCs and several browsers to no effect.  I've switched on / off the router, but have not yet tried a factory reset.
I'm using a BT Smart Hub 2 which has the Plusnet DNS addresses built-in.  My next move is to try my laptop from a neighbour's network.  For whatever reason, I suspect my IP address is not being accepted by the Woosh web-site.  Why? I don't know.
If that is the case, I don't know if it is possible for Plusnet to assign me to a different IP address.  I'll see how I get on when I try to connect from my neighbour's router.
I find very odd that every other web-site I use connects without issue, just this one single site seems to cause me a problem.
Fixes: 162
Revisiting this from a desktop and doing a swift Google search suggests that the vendor's website has access limits on it, something that they are probably not aware of.  It is one thing to suggest "We can see no problems" but it is not the same as "there are no problems".  There clearly is and it will be something beyond simple - probably a restriction imposed by their website hosting company.
The fact that you can access over 4G narrows down the scope of the issue to your Plusnet IP address, somewhat as you suggest.  One possibility is the use of stale IP address geolocation data.  You might try the following...
  1. Go to https://whatismyipaddress.com/ to display your (external) IP address and location - write them down
  2. Go to https://www.iplocation.net/ip-lookup to see if there is any variability in the location details - specifically non-UK
  3. Turn off your router and leave it turned off for at least 90 minutes
  4. Repeat 1 and 2 above after restarting the router
There is some possibility that your current IP address is associated with non-UK Geolocation data.  This can arise from IPv4 address ranges being transferred to the UK conjoined with poor revision of geolocation data from such vendors and / or the website hosting provider (or user) not updating said data.
Step (3) should cause your sticky dynamic IP address to become non-sticky so that you are allocated a different dynamic IP address.
Should (2) indicate that the IP address is reported as not UK based (by one or more data providers), then that is valuable information to feedback to the site owner.
Jodel
Townman,
Thanks for your detailed response.  I can connect with no problem from a neighbour's router, so as you say it is probably an issue with my IP address. I won't have a chance to carry out your suggested fix for a few days, but I will update this thread as soon as I can.
Thanks!
Jodel
Update:
I tried switching off my router overnight to give it plenty of time to 'clear'.  Unfortunately, this has not made any difference as I still can't connect to the Woosh web-site.
Using the IP look-up links from Townman, my IP address is showing as located in the UK and doesn't have any evidence of blacklisting.
Can PlusNet manually re-set my external IP address and I'll try connecting again?
Fixes: 162
Did you get a different IP address?
Jodel
Townman, sorry I should have said that my IP address didn't change despite switching off the router overnight.
Fixes: 162
What is the A.B. Of your A.B.C.D IP address?
Do you know if you have a static IP address?
Jodel
Hi,  A.B. is: 31.125.X.X
I don't have a static I.P. address as far as I know.
Aspiring Hero
Fixes: 78
@Jodel
If you use this site https://whatismyhostname.com/ it will help to indicate if you have a dynamic or static IP Address
Look at  Your Hostname:
Dynamic would be something like 0.0.208.46.dyn.plus.net
Anything else is likely to be static example <youraccountname>.plus.net or xxx-xxx-xxx-xxx.plus.net where xxx-xxx-xxx-xxx is the public IP Address in reverse order. So 192.168.1.10 would be 10-1-168-192
HTH
Jodel
Thanks - tried the link and it looks like I have a static address.  Does that help in identifying the issue?  Sorry, I'm not too clued-up on the connectivity side of things.
pvmb
That is exactly the current prefix to my IP address and yet I too can connect to the Woosh website. Seemingly with a dynamic address.
Fixes: 162
Given the profile of the problem it seems to be attached to the IP address. Given its static, the method I described above will not get you a different address.
This needs the help of staff - either to determine why the address is being blocked or to get a different static IP address assigned.
Are you using the Plusnet firewall?
@willcutforth / @MatthewWheeler can you get assistance from NetOps please?
